Giriş
Hip and trendy home automation startup Nest Labs has dumped some smarts into the dumbest device in your home: the smoke alarm. Curious about just what goes into this sort of thing, we did what we do best: took one apart.
Need more electronic monitoring than this teardown, or a Nest system, can offer? Follow our Twitter updates, Facebook posts, and Instagram snaps for full coverage.
Welcome to the world, Nest Protect. Perhaps you will vanquish the ear melting, banshee cry of the over-excited smoke detectors installed in every home we've ever cooked in. Let's see what you're packing:
Available with 6 AA Energizer Ultimate Lithium batteries or Wired for 120 V
Wi-Fi connectivity and wireless mesh networking with other Nest units
Photoelectric smoke sensor and carbon monoxide sensor
Heat and humidity sensors
Three activity sensors
Ambient light sensor
First stop: pop the top off the Nest button, the combination input switch and multi-colored sweeping light.
An ambient light sensor sits in the center of the button, with lenses in the translucent cover to increase its viewing angle.
A ring of RGB LEDs surround the sensor to make up the Protect's indicator glow:
White for the automatic night light
Reassuring green to indicate all's clear
Yellow for an early warning
Red for a get-out-of-town emergency
The device in the center is a Passive Infrared Sensor. The lense is used for both increasing the viewing angle and allowing for motion detection.
Hi!, nice Nest protect teardown.
I would like to know, if removing or somehow silencing the alarm speaker, the Nest would still work?
Could i add something to the speaker to make it not that loud?
I know it is a weird question!
Please, let me know!
Thanks!
Use a adhesive tape to make it lower , the more tape the lower.
Tien -
We pull out the impressive-for-a-smoke-detector main board, and the optical smoke detector is front and center, safely under its baffled shield.
As smoke enters the baffled chamber above the sensor, infrared light from the LED is scattered and reflected down into the photodiode, triggering the alarm. This sort of arrangement is standard practice for smoke detectors.
But applying the Nest Labs touch means adding all sorts of extra features for handling the alarm, like sending a notification to your smartphone that your house is on fire. Neat.
A little further into the device, and we find the CO detector, disguised as a capacitor in a tiny metal barn.
The Figaro TGS5342 electrochemical carbon monoxide detector works like a little fuel cell—the presence of carbon monoxide drives a chemical reaction that generates current proportional to the CO concentration in the air.
The detector's measuring circuitry is on the reverse side of the main board, encased in some clear adhesive—likely to protect it against shock and the atmosphere.
If a fire or CO leak is detected, an 85 dB horn raises the alarm while a separate speaker tells you to exit the building in the talking-bomb-countdown-timer voice.
Straight and angled motion sensors catch your waving arm when you want to silence a false alarm from cooking smoke or a steamy shower.
Down now to the heart of the brain (Just ponder that metaphor for a moment. Done? Wonderful, let’s move on). A quick look at the noteworthy integrated circuits running the Nest Protect:
Freescale SCK60DN512VLL10 custom Kinetis K60 low-power 100 MHz MCU
Silicon Labs EM357 Ember Zigbee SoC
Freescale SCKL16Z128V custom Kinetis KL1x general purpose MCU
Texas Instruments LM324A quadruple op-amp
Murata Type ZX 2.4 GHz Wi-Fi 802.11b/g/n module (with Broadcom BCM43362 chipset)
Texas Instruments TPS62737 Step-Down Buck Converter
The Nest Protect is straight-forward and easy to disassemble. Common screw types, user-accessible batteries, and a simple design make it a very solid, repairable product.
That said, we won't be assigning a repairability score, considering you probably shouldn't do anything more than replace the batteries in your Nest Protect.
Nice tear down !!!
The tear down has details for only the CO sensor but missing the names for the rest.
Like the Photoelectric smoke sensor, motion sensor, temp, humidity, light sensor.
Just eager to know the sensors used in nest.
17 Yorum
Any clue to what the 3rd wire on the socket is for? They only provide a two wire harness. My guess is related to the alarm integration -- possibly able to be used as an interconnect to existing alarms (if a 9V signal), too?
And uses ninety six batteries lol
I would like to know also.
All Nest Protects have 6 battery slots and a wiring plug. In a hardwired situation the back cover has a hole for that connector. It also has a little cover that blocks 3 of the battery bays. Battery operated alarms have a back cover that blocks the port.
Logan -
Do we know what time of screws it uses on the outside? I Need to replace them
Do you know the size of the two screws for the battery cover backing? I need to find replacement screws. Another chat forum mentioned that they were 1.6mm in diameter but no mention of length. Is this something that ifixit would sell?
Bonjour j'aurais voulu savoir s'il était possible de régler la longueur de détection de mouvement ayant installé le détecteur dans une chambre près de l'entrée ayant une chambre de dimensions standard je me suis aperçu qu'en étant au lit le détecteur s'allume lorsque je bouge et donc me réveille assez régulièrement et ne voulant pas la supprimer définitivement pouvez-vous s'il vous plaît me trouver une solution merci
Mine continues to show and ding indicating LOW BATTERY even after replacing the 6 AA batteries. Nest labs sent me a new one and claimed the internal CMOS battery on my original one was depleted, which explains why it continues to say Low Battery with brand new 6 AA alkaline ones. I wonder if this “internal battery” is a replaceable off-the-shelf cell type. Of course, Nest Labs didn’t think twice about replacing the whole thing due to the safety risk involved in repairing this one. So, has anyone had to replace such internal battery or even knows where it’s located?
Just wondering if it is possible to somehow mask the “optical smoke detector” to disable that function as I am only looking to install this in the kitchen and use it as Heat & CO sensor.
Unfortunately, Nest has been ignoring repeated requests to allow users to disable the Smoke detector function via app/firmware so trying to find an alternative.
Comments from anyone with such experiences will be greatly appreciated. Thank you
I just dissected my expired Protect, I’d love to reuse as much as possible from this thing for a general purpose sensor. Nest is never going to give anyone access to enough information to repurpose the main circuit board on these but I think it might be possible to design a replacement board that uses an ESP32 and integrates with something like ESPHome. The case, PIR, leds, speaker, and power supply/batteries should be easy to tie into a new PCB. Salvaging other components like the ultrasonic sensors, buzzer, smoke, light, and temp/humidity is technically doable but might not be worth it in the end.
Anybody know where I can get spares? Forgot the power cable at old house and nest don’t supply spares, can I use the usb as power?
Has anyone done a teardown of the 2nd Gen? I’d like to know if it is possible to get into the photosensitive detector to clean it properly. It keeps reporting a fault which goes for a while after being hoovered out, but then returns.
where is three activity sensors?
sjh835170 - Yanıt
