Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Netgear Router cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: adım 1, 3 resimden 1. Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: adım 1, 3 resimden 2. Netgear G54 Wireless Router Teardown, NetGear G54 Wireless Router: adım 1, 3 resimden 3.
    • Flip the Net Gear wireless Router over remove four rubber tabs .
    • Place them to the side
  2. Netgear G54 Wireless Router Teardown, Removing  the rubber tabs: adım 2, 1 resimden 1.
    • There four screws that need to be removed.
  3. Netgear G54 Wireless Router Teardown, Removing the four bottom screws: adım 3, 3 resimden 1. Netgear G54 Wireless Router Teardown, Removing the four bottom screws: adım 3, 3 resimden 2. Netgear G54 Wireless Router Teardown, Removing the four bottom screws: adım 3, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the four screws.
    • Place them aside
  4. Netgear G54 Wireless Router Teardown, Removing the case: adım 4, 3 resimden 1. Netgear G54 Wireless Router Teardown, Removing the case: adım 4, 3 resimden 2. Netgear G54 Wireless Router Teardown, Removing the case: adım 4, 3 resimden 3.
    • Removing the bottom top facing up .
    • Put it to the side.
  5. Netgear G54 Wireless Router Teardown, Removing  the front clear plastic: adım 5, 2 resimden 1. Netgear G54 Wireless Router Teardown, Removing  the front clear plastic: adım 5, 2 resimden 2.
    • Use a spudger on the edge of the clear hard plastic around the outer casing.
    • Use a spudger on the edge to push up the plastic casing.
    • Once the clear plastic casing is removed, place it to the side.
  6. Netgear G54 Wireless Router Teardown, Removing the motherboard: adım 6, 3 resimden 1. Netgear G54 Wireless Router Teardown, Removing the motherboard: adım 6, 3 resimden 2. Netgear G54 Wireless Router Teardown, Removing the motherboard: adım 6, 3 resimden 3.
    • Remove the motherboard with bottom case. Then you are done.
  7. Netgear G54 Wireless Router Teardown: adım 7, 1 resimden 1.
    • After remove the motherboard . The top cases of the Router.
kempc8
899 İtibar
7 adet Kılavuz yazıldı
Ekip
K and K Fixit K and K Fixit üyesi
Business
1 Üye
11 adet Kılavuz yazıldı
2 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 19
Her zaman: 2,880
