Giriş
A teardown the NetGEAR 54 Wireless Router
Neye ihtiyacın var
Flip the Net Gear wireless Router over remove four rubber tabs .
Place them to the side
Use a Phillips #00 screwdriver to remove the four screws.
Place them aside
Use a spudger on the edge of the clear hard plastic around the outer casing.
Use a spudger on the edge to push up the plastic casing.
Once the clear plastic casing is removed, place it to the side.
2Kılavuz Yorumları
bad quality images
bad teardown!
