Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Nikon 1 J5 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Nikon 1 J5 Teardown (repair purpose), Nikon 1 J5 Teardown (repair purpose): adım 1, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Nikon 1 J5 Teardown (repair purpose): adım 1, 2 resimden 2.
    • Remove Lens, MicroSD Card and Battery
  2. Nikon 1 J5 Teardown (repair purpose), Remove/Replace LCD/Touchscreen: adım 2, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Remove/Replace LCD/Touchscreen: adım 2, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Remove/Replace LCD/Touchscreen: adım 2, 3 resimden 3.
    • Remove 2 screws first
    • Lift the cover
    • Disconnect LCD FPC
    • Then remove 4 screws
    • Remove LCD assembly
  3. Nikon 1 J5 Teardown (repair purpose), The LCD assembly and FPC connector: adım 3, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), The LCD assembly and FPC connector: adım 3, 2 resimden 2.
    • Insert wisdom here.
  4. Nikon 1 J5 Teardown (repair purpose), Bottom side: adım 4, 1 resimden 1.
    • Remove 2 screws
  5. Nikon 1 J5 Teardown (repair purpose), Left Side(The LEFT when you holding it the right way): adım 5, 1 resimden 1.
    • Open connection bay
    • Remove 2 screws
  6. Nikon 1 J5 Teardown (repair purpose), Right side(the RIGHT when you holding it the right way): adım 6, 1 resimden 1.
    • Remove 1 screw under the DC power cable notch cover
  7. Nikon 1 J5 Teardown (repair purpose), Back side(again): adım 7, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Back side(again): adım 7, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Back side(again): adım 7, 3 resimden 3.
    • Remove 4 screws and be ware the length difference
    • Peel the rubber open from right hand side
    • Remove 1 screw
  8. Nikon 1 J5 Teardown (repair purpose), Back case: adım 8, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Back case: adım 8, 2 resimden 2.
    • Now the back case can be removed.
    • There's no fragile FPC or cables in this step. Just be patient.
  9. Nikon 1 J5 Teardown (repair purpose), Keypad: adım 9, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Keypad: adım 9, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Keypad: adım 9, 3 resimden 3.
    • Disconnect speaker cable
    • Pull out keypad cable
  10. Nikon 1 J5 Teardown (repair purpose): adım 10, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose): adım 10, 2 resimden 2.
    • Insert small crowbar or flat head screw driver here to lift the keypad up.
    • Those clips are very tight.
  11. Nikon 1 J5 Teardown (repair purpose), Shielding cover: adım 11, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Shielding cover: adım 11, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Shielding cover: adım 11, 3 resimden 3.
    • Remove 3 screws
    • Remove 2 screws
    • Notice the sizes of screws
  12. Nikon 1 J5 Teardown (repair purpose), Shielding cover: adım 12, 1 resimden 1.
    • Need some tape peeling
  13. Nikon 1 J5 Teardown (repair purpose), Discharge flash reservoir capacitor: adım 13, 1 resimden 1.
    • Dangerous DC Voltage > 200V, stored in a 330V 80uF capacitor set.
    • Flash xenon tube terminals, positive connected to capacitor, negative controlled by circuit, and a trigger signal.
    • Use 10kohm, >2W resistor, connect 2 solder joints for more than 5sec. These are flash condenser/capacitor terminals. DO NOT discharge by SHORT them. (Note 2020-10-13)
    • DMM's Low-Z voltage works even better, also safer.
    • Measure voltage between 2 solder joints to ensure voltage <10V
  14. Nikon 1 J5 Teardown (repair purpose), FPC connectors: adım 14, 1 resimden 1.
    • Flash solenoid and detecter
    • Microphones and AF assistant LED
    • Keypad
    • Switches
    • NFC
    • WiFi and Bluetooth, Lens(back)
    • CMOS sensor
    • LCD
  15. Nikon 1 J5 Teardown (repair purpose), Main PCB 1: adım 15, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Main PCB 1: adım 15, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Main PCB 1: adım 15, 3 resimden 3.
    • Detach every FPC you can find
  16. Nikon 1 J5 Teardown (repair purpose), Main PCB 2: adım 16, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Main PCB 2: adım 16, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Main PCB 2: adım 16, 3 resimden 3.
  17. Nikon 1 J5 Teardown (repair purpose), Main PCB 3: adım 17, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Main PCB 3: adım 17, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Main PCB 3: adım 17, 3 resimden 3.
    • Desolder flash condenser FPC and Flash cables (remember to discharge first)
  18. Nikon 1 J5 Teardown (repair purpose), Main PCB 4: adım 18, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Main PCB 4: adım 18, 2 resimden 2.
    • More FPC
  19. Nikon 1 J5 Teardown (repair purpose), Main PCB 5: adım 19, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Main PCB 5: adım 19, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Main PCB 5: adım 19, 3 resimden 3.
    • Lift Main PCB, SLOWLY and GENTLY
    • One more FPC at the back side.
  20. Nikon 1 J5 Teardown (repair purpose), Behold, The Main PCB: adım 20, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Behold, The Main PCB: adım 20, 2 resimden 2.
  21. Nikon 1 J5 Teardown (repair purpose): adım 21, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose): adım 21, 2 resimden 2.
    • Mark 3 screws for their ID and position.
    • Also record how many turns to the limit.
    • Measure and record distance to front flange if possible.
    • These screws will affect focus focal plain.
  22. Nikon 1 J5 Teardown (repair purpose), Behold, the sensor: adım 22, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Behold, the sensor: adım 22, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Behold, the sensor: adım 22, 3 resimden 3.
    • Sensor module and IR-cut filter
  23. Nikon 1 J5 Teardown (repair purpose), Remove IR-cut: adım 23, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Remove IR-cut: adım 23, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Remove IR-cut: adım 23, 3 resimden 3.
    • Hold the IR-cut filter by its edge, to avoid scratches and contamination.
    • Use plastic tweezers can avoid scratches.
  24. Nikon 1 J5 Teardown (repair purpose), The sensor itself: adım 24, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), The sensor itself: adım 24, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), The sensor itself: adım 24, 3 resimden 3.
    • And I don't quite remember what is this filter/window.
  25. Nikon 1 J5 Teardown (repair purpose), Battery bay: adım 25, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Battery bay: adım 25, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Battery bay: adım 25, 3 resimden 3.
    • remove 2 self tap screws (upper and lower)
    • Sorry for the magical color change of victim camera and chaotic white balance on of my desk(mixed warm LED and flash).
  26. Nikon 1 J5 Teardown (repair purpose), The battery bay: adım 26, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), The battery bay: adım 26, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), The battery bay: adım 26, 3 resimden 3.
  27. Nikon 1 J5 Teardown (repair purpose), Top Case 1: adım 27, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Top Case 1: adım 27, 2 resimden 2.
    • Pop up flash by pulling up the solenoid
    • Remove screw in flash bay
  28. Nikon 1 J5 Teardown (repair purpose), Top case 2: adım 28, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Top case 2: adım 28, 2 resimden 2.
    • Remove 2 self tap screws
  29. Nikon 1 J5 Teardown (repair purpose), Top Case 3: adım 29, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Top Case 3: adım 29, 2 resimden 2.
    • Now you can wiggle off top case.
    • Only 3 small clips
  30. Nikon 1 J5 Teardown (repair purpose), Flash head: adım 30, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Flash head: adım 30, 2 resimden 2.
    • Remove this screw
    • Remove flash head
  31. Nikon 1 J5 Teardown (repair purpose), Top case 4: adım 31, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Top case 4: adım 31, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Top case 4: adım 31, 3 resimden 3.
    • Top Case
    • AF assistant LED and left Microphone
    • Switch board. Right microphone, power switch, shutter button, mode dial, main command dial.
  32. Nikon 1 J5 Teardown (repair purpose): adım 32, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose): adım 32, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose): adım 32, 3 resimden 3.
    • screws
    • FPC
    • Sneaky screw
  33. Nikon 1 J5 Teardown (repair purpose), Mode dial cap: adım 33, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Mode dial cap: adım 33, 2 resimden 2.
    • Mode dial cap is double sided taped,
    • Remove switch board.
    • Someone else already murdered the main dial and video record button...
  34. Nikon 1 J5 Teardown (repair purpose): adım 34, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose): adım 34, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose): adım 34, 3 resimden 3.
    • Light guide
    • other angles
  35. Nikon 1 J5 Teardown (repair purpose), Mode Dial: adım 35, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Mode Dial: adım 35, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Mode Dial: adım 35, 3 resimden 3.
    • Sneakier screw
  36. Nikon 1 J5 Teardown (repair purpose), Power switch and shutter button: adım 36, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Power switch and shutter button: adım 36, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Power switch and shutter button: adım 36, 3 resimden 3.
    • sc...s
  37. Nikon 1 J5 Teardown (repair purpose), Sensor and focus adj: adım 37, 1 resimden 1.
    • Focus adjust and focal plane calibration is important to par-focal lenses
  38. Nikon 1 J5 Teardown (repair purpose), Battery latch: adım 38, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Battery latch: adım 38, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Battery latch: adım 38, 3 resimden 3.
  39. Nikon 1 J5 Teardown (repair purpose), Lens mount: adım 39, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Lens mount: adım 39, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Lens mount: adım 39, 3 resimden 3.
    • and lens contacts
  40. Nikon 1 J5 Teardown (repair purpose), Lens contacts: adım 40, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Lens contacts: adım 40, 2 resimden 2.
  41. Nikon 1 J5 Teardown (repair purpose), take apart everything: adım 41, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), take apart everything: adım 41, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), take apart everything: adım 41, 3 resimden 3.
  42. Nikon 1 J5 Teardown (repair purpose), Flash capacitor: adım 42, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Flash capacitor: adım 42, 2 resimden 2.
    • Capacitor / condenser, which do you prefer?
  43. Nikon 1 J5 Teardown (repair purpose), Wireless module: adım 43, 3 resimden 1. Nikon 1 J5 Teardown (repair purpose), Wireless module: adım 43, 3 resimden 2. Nikon 1 J5 Teardown (repair purpose), Wireless module: adım 43, 3 resimden 3.
    • WiFi and bluetooth
    • Lens latch pin
  44. Nikon 1 J5 Teardown (repair purpose), Wiireless module: adım 44, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), Wiireless module: adım 44, 2 resimden 2.
    • This one is liquid damaged
  45. Nikon 1 J5 Teardown (repair purpose), NFC module: adım 45, 1 resimden 1.
    • under the shield
  46. Nikon 1 J5 Teardown (repair purpose), More pics: adım 46, 2 resimden 1. Nikon 1 J5 Teardown (repair purpose), More pics: adım 46, 2 resimden 2.
  47. Nikon 1 J5 Teardown (repair purpose), More pics: adım 47, 1 resimden 1.
Terrance
6.368 İtibar
17 adet Kılavuz yazıldı
12 Yorum
Hi Terrance - the return spring on the on/off switch has gone on mine - are you able to see how to get at this on your stripped down one?
freecycle at evendine dot eclipse dot co dot uk in case I don’t notice it coming up here
chris morton - Yanıt
hmm, haven’t dug that deep yet… The front case disassembly seems very tricky. Also the IR-cut removal.
Terrance -
Sorry to hear that, I arrive here coming for a solution for the return spring on the on/off switch, is not a big problem but a pain and battery drain if you don’t realise :)
Anyway thanks for your teardown really formative.
juan valderrabano - Yanıt
I tried to remove the top cover to repair the return spring on the ON/OFF, but I was not able to separate it from the body. I have no solution.
Jacques Guyon - Yanıt
I finally got my hands on a wasted 1J5 and go on with the tear down. FYI top cover is sort of easy to remove, but very tricky. post more photos later.
I some simple words, after removing main PCB, remove some screws from left-upper right-upper and inside flash bay,you can wiggle the top clean off.
And, the power switch is berried very deep. you have to fond all sneaky screws. Aaaaaand the mode dial cap is double-side-taped, some thermal energy needed.
Terrance -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 169
Her zaman: 3,195
