Giriş
Got your old DS and looking to relive some childhood memories? Too bad. Here we take a look into the guts of your toy, and go into the Teardown of your device. This tutorial shows how to disassemble your DS device, and see how that piece of magic had worked. Enjoy!
Neye ihtiyacın var
First things first, get out that old DS. Admire it in it's glory, because it's not going to look like that for long!
Using the Phillips head screwdriver, remove any and all screws from the back ports of the DS.
Place the spudger in either of the line edges near the game port, and then place it inward, forcing it to separate the two parts.
Taking this, then gently but firmly move it along the inside until the edge of that side of the DS, making sure not going in too far into the DS.
After removing all of your larger machine components, you need to have the electronics board and plastic segments entirely seperate.
Take your spudger, and lightly place it underneath the small Wi-Fi Board, beginning to apply small amounts of pressure. Remove the board.
Now take the black and white wires present near the Wi-Fi Board, and start with placing your spudger thumbnail on the black wire.
Partially seperate your upper case and lower motherboard, creating a short distance between the two.
It's at this point that most DS Teardowns and Part Replacements end.
Further Teardown focuses more on the previously mentioned ribbon and wi-fi cables connections to the upper screen, and with this the presence of the microphone ports.
To reassemble your device, follow these instructions in reverse order. Be sure to be very careful with the screw and cable placement of separate components of your DS, misplaced parts can either break or damage your system
Further information and process steps can be found here.
Ekli Belgeler
1Rehber Yorum
Thank you for this tutorial! I have a nintendo DS that I'd like to replace the screen on and maybe switch cases. Just wondering if you can reassemble everything without having to solder? (sorry if that's a silly question, electronic repairs both terrify and intrigue me lol)
Thanks! -Stacey
