Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Nintendo DS Lite cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Nintendo DS Lite Teardown, Part  Seperartion: adım 1, 1 resimden 1.
    • Your first step would be to unscrew all all screws on the back and take the case off. You take the case off by placing a spudger on the line edges , and then place it inward, forcing it to separate the two parts.
  2. Nintendo DS Lite Teardown, WI-FI board: adım 2, 1 resimden 1.
    • You first remove the gabbles by gently pulling them and do the same for the WI-FI board
  3. Nintendo DS Lite Teardown, Screen Removal: adım 3, 1 resimden 1.
    • You take the mother board off by flipping the upside-down and the screen should pop right off.
  4. Nintendo DS Lite Teardown: adım 4, 1 resimden 1.
    • Unscrew and gently slide wires through frame
  5. Nintendo DS Lite Teardown, Final Look: adım 5, 1 resimden 1.
    • The DS should look like this and to put the DS back together simply follow steps back wards.
Isabella Sandoval
182 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Don’t like this guide. Only a few steps. Tear downs usually have 50+. Add more and in detail.
Bob - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 38
Son 30 gün: 117
Her zaman: 2,723
