Giriş
Explanatory Guide of how to teardown a Nintendo GameCube.
Bu teardown bir tamir kılavuzu değildir. Nintendo GameCube cihazınızı onarmak için, servis kılavuzumuzu kullanın.
Flip unit over and locate the four screws shown in the second photograph. Remove four corner screws located on the underbelly of the unit using the Nintendo Gamecube bit tool.
  • Flip unit over and locate the four screws shown in the second photograph.
  • Remove four corner screws located on the underbelly of the unit using the Nintendo Gamecube bit tool.
Yorum Ekle
Pull bottom half of unit away from top outer casing. Pull bottom half of unit away from top outer casing. Pull bottom half of unit away from top outer casing.
  • Pull bottom half of unit away from top outer casing.
Yorum Ekle
Depress clips and remove back panel as shown.
  • Depress clips and remove back panel as shown.
Yorum Ekle
Carefully unclip controller ports in the front of the unit.
  • Carefully unclip controller ports in the front of the unit.
  • Ribbon Cable (in yellow) is still attached to the unit. Do not try to disconnect this cable.
Yorum Ekle
Unscrew the two screws holding the fan assembly onto the unit using a Philips #2 screwdriver as shown. Carefully remove the red and black wiring assembly from the fan unit by gently pulling the fan connector away from the fan as shown.
  • Unscrew the two screws holding the fan assembly onto the unit using a Philips #2 screwdriver as shown.
  • Carefully remove the red and black wiring assembly from the fan unit by gently pulling the fan connector away from the fan as shown.
Yorum Ekle
Remove four screws using a Philips #1 screwdriver as shown. Carefully remove metal plates as shown in second photograph
  • Remove four screws using a Philips #1 screwdriver as shown.
  • Carefully remove metal plates as shown in second photograph
Yorum Ekle
Mac RAM Kitleri
Mac'inizi hızlandırın. Hafızasını en yükseğe çıkar.
Mac RAM Kitleri
Mac'inize daha fazla bellek alın.
Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver. Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver. Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver.
  • Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver.
Yorum Ekle
Carefully lift drive assembly off of the base. Carefully lift drive assembly off of the base. Carefully lift drive assembly off of the base.
  • Carefully lift drive assembly off of the base.
Yorum Ekle
Flip drive assembly over and remove 8 screws as shown. Remove metal plate, careful to not disturb the brown wire (shown in yellow)
  • Flip drive assembly over and remove 8 screws as shown.
  • Remove metal plate, careful to not disturb the brown wire (shown in yellow)
There's actually only 6 screws to remove-- two of the circled objects are placement pegs.
Kevin K - Yanıt
Gently slide out black clip holding the brown ribbon in place. Then slide out brown ribbon as shown. Gently slide out black clip holding the brown ribbon in place. Then slide out brown ribbon as shown.
  • Gently slide out black clip holding the brown ribbon in place. Then slide out brown ribbon as shown.
Yorum Ekle
Carefully remove blue wire Remove four screws with a #1 Phillips Screwdriver Remove four screws with a #1 Phillips Screwdriver
  • Carefully remove blue wire
  • Remove four screws with a #1 Phillips Screwdriver
Yorum Ekle
Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes) Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes) Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes)
  • Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes)
Yorum Ekle
Using a flat-head screwdriver or other long flat object, carefully release the four plastic clips holding the drive assembly together. The last clip can be rather hard to find.  Use a screwdriver as shown in the third image to get behind the plastic to release the last clip (in blue). The last clip can be rather hard to find.  Use a screwdriver as shown in the third image to get behind the plastic to release the last clip (in blue).
  • Using a flat-head screwdriver or other long flat object, carefully release the four plastic clips holding the drive assembly together.
  • The last clip can be rather hard to find. Use a screwdriver as shown in the third image to get behind the plastic to release the last clip (in blue).
Yorum Ekle
Lift metal plate off of drive assembly, again being careful not to sever the two wires still attached to the two halves of the drive assembly. Next, flip and rotate the drive assembly so that it resembles the one in the third picture. Next, flip and rotate the drive assembly so that it resembles the one in the third picture.
  • Lift metal plate off of drive assembly, again being careful not to sever the two wires still attached to the two halves of the drive assembly.
  • Next, flip and rotate the drive assembly so that it resembles the one in the third picture.
Yorum Ekle
Using the screwdriver, release two more clips around the back half of the drive assembly. The last clip doesn't need to be released, the top half of the drive assembly will slide away from the lower half. The last clip doesn't need to be released, the top half of the drive assembly will slide away from the lower half.
  • Using the screwdriver, release two more clips around the back half of the drive assembly.
  • The last clip doesn't need to be released, the top half of the drive assembly will slide away from the lower half.
Yorum Ekle
Finish removing the top half of the drive assembly, be careful as this piece is where the two wires that should not be removed are attached to (unless you want to do some soldering). Finish removing the top half of the drive assembly, be careful as this piece is where the two wires that should not be removed are attached to (unless you want to do some soldering).
  • Finish removing the top half of the drive assembly, be careful as this piece is where the two wires that should not be removed are attached to (unless you want to do some soldering).
Yorum Ekle
Remove three final screws near the bars of the lens assembly.  Once this is done the lens assembly can be removed. Remove three final screws near the bars of the lens assembly.  Once this is done the lens assembly can be removed.
  • Remove three final screws near the bars of the lens assembly. Once this is done the lens assembly can be removed.
Yorum Ekle
Shown in the first picture is the lens assembly.  In the second, the drive assembly without the lens assembly. Congratulations, you're done!
  • Shown in the first picture is the lens assembly. In the second, the drive assembly without the lens assembly.
  • Congratulations, you're done!
Yorum Ekle
agronbac
594 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G2
4 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 Gün: 24
Son 30 Gün: 96
Her zaman: 21,187
