Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Niterider Bike Headlight cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Niterider Bike Headlight Teardown, Open Enclosure: adım 1, 1 resimden 1.
    • Find and extract a Philips screw at bottom of the device.
  2. Niterider Bike Headlight Teardown: adım 2, 1 resimden 1.
    • Slide PCB and battery out of the enclosure by pulling on the lens at the front of the device.
  3. Niterider Bike Headlight Teardown: adım 3, 1 resimden 1.
    • Un-clip the plastic lens from the black plastic clip and PCB.
  4. Niterider Bike Headlight Teardown: adım 4, 1 resimden 1.
    • Remove Philips screws from black plastic clip and carefully remove the PCB from the plastic.
  5. Niterider Bike Headlight Teardown: adım 5, 1 resimden 1.
    • Carefully peel battery away from the PCB by breaking the adhesive. After repair the battery will barely stick to the adhesive but the enclosure can still hold the battery in place. The ruined adhesive could be replaced with new adhesive if desired.
  6. Niterider Bike Headlight Teardown: adım 6, 3 resimden 1. Niterider Bike Headlight Teardown: adım 6, 3 resimden 2. Niterider Bike Headlight Teardown: adım 6, 3 resimden 3.
    • The yellow tape may be removed from the battery and the voltage regulation PCB can be bent away from the battery in order to access the voltage regulation chip and constant current LED driver chip for repair. Solder rework can be done here after detaching (de-soldering) the battery.
Samuel Keechler
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 326
