Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Adapter cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Nokia AC-16U USB Power Adapter Teardown, Crack Open The Case: adım 1, 3 resimden 1. Nokia AC-16U USB Power Adapter Teardown, Crack Open The Case: adım 1, 3 resimden 2. Nokia AC-16U USB Power Adapter Teardown, Crack Open The Case: adım 1, 3 resimden 3.
    • This power supply is slim and unusually attractive.
    • That white case is 39mm in diameter, and 15mm thick: pretty small for this power level (see heat sinks later).
    • The case is glued together, so you're not going to get into this one cleanly. I sawed a slot in the side, and used a screwdriver to crack the glue.
  2. Nokia AC-16U USB Power Adapter Teardown, What's Inside?: adım 2, 3 resimden 1. Nokia AC-16U USB Power Adapter Teardown, What's Inside?: adım 2, 3 resimden 2. Nokia AC-16U USB Power Adapter Teardown, What's Inside?: adım 2, 3 resimden 3.
    • The wall power pins lead to two spring contacts.
    • There's a plastic barrier between the low voltage and high voltage sides (you can't get much better than that!).
  3. Nokia AC-16U USB Power Adapter Teardown, How about some detailed PCB Photos?: adım 3, 2 resimden 1. Nokia AC-16U USB Power Adapter Teardown, How about some detailed PCB Photos?: adım 3, 2 resimden 2.
    • Pretty tight layout.
    • Note the heat sink with thermal interface material, and the landing pads for the line voltage springs.
Bryce Nesbitt
1.023 İtibar
9 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 2,373
