Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. OWC Thunderbolt 3 Pro Dock cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. OWC Thunderbolt 3 Pro Dock Teardown, The start: adım 1, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, The start: adım 1, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, The start: adım 1, 3 resimden 3.
    • Flip dock upside down and remove rubber feet
  2. OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: adım 2, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: adım 2, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, Removing bottom cover: adım 2, 3 resimden 3.
    • Remove bottom plate screws and remove bottom plate
    • Make sure to use a TORX TR8 head for the bottom screws
  3. OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: adım 3, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: adım 3, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, Removing the mainboard: adım 3, 3 resimden 3.
    • Remove the mainboard and its three screws
    • Use a TORX TR8 for all of these screws
    • Make sure to unplug the fan on the other side as it is still connected to the chassis, it may need some persuasion as the connector is really in there
    • When removing the mainboard be gentle as the front I/O sits flush to the chassis otherwise you might damage it.
  4. OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: adım 4, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: adım 4, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, Removing top plate: adım 4, 3 resimden 3.
    • Remove the four TORX TR8 screws
    • Pry the top plate away from the main chassis, this may take some persuasion as the top plate is glued in a bit
  5. OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: adım 5, 2 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Removing NIC heatsink: adım 5, 2 resimden 2.
    • Remove the two TORX TR8 screws to remove the heatsink
    • It is highly recommended to clean the surface from whatever residue the thermal pad has left behind to increase longevity of the dock
  6. OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: adım 6, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: adım 6, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, Removing fan: adım 6, 3 resimden 3.
    • Switch to a TORX TR10 bit for the fan screws
    • The fan model is a sunon HA40101V4-1D070-G99
    • When the screws are out the fan should just fall out
  7. OWC Thunderbolt 3 Pro Dock Teardown, Everything spread out: adım 7, 1 resimden 1.
  8. OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: adım 8, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: adım 8, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, A look at half of the mainboard: adım 8, 3 resimden 3.
    • sample text, the photos speak for themselves
    • The 10Gbe NIC is the Aquantia AQC107S-B1-C
  9. OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: adım 9, 2 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, A look at the other half: adım 9, 2 resimden 2.
    • Insert wisdom here. - indeed
  10. OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: adım 10, 2 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Measurements of the NIC: adım 10, 2 resimden 2.
    • I cant figure out how to put more than 3 pics in one step, so the ended up here.
  11. OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: adım 11, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: adım 11, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, Putting the heatsink back: adım 11, 3 resimden 3.
    • Support the heatsink and line it up with the holes on the top of the chassis
    • Re-install the two TORX TR8 screws to hold in the heatsink
  12. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: adım 12, 2 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing fan: adım 12, 2 resimden 2.
    • Line up the fan with the holes
    • Screw the fan back in with the TORX TR10 screws
  13. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: adım 13, 2 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing the top lid: adım 13, 2 resimden 2.
    • Line up the top lid with the main chassis, make sure to have the fan vent in the correct orientation so it can breathe.
    • Screw the lid back in with the four TORX TR8 screws
  14. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: adım 14, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: adım 14, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown, Re-installing mainboard: adım 14, 3 resimden 3.
    • Put the mainboard back into the main chassis, make sure to be gentile and line up the rear I/O first and then slowly lower in the other side.
    • Secure the mainboard with the 3 TORX TR8 screws. - no you arent missing any the rest of the screws go through the bottom cover
  15. OWC Thunderbolt 3 Pro Dock Teardown: adım 15, 3 resimden 1. OWC Thunderbolt 3 Pro Dock Teardown: adım 15, 3 resimden 2. OWC Thunderbolt 3 Pro Dock Teardown: adım 15, 3 resimden 3.
    • Line up the bottom cover, !make sure to use the orientation that is shown in the photo otherwise it will not line up!
    • Secure the bottom cover with the four TORX TR8 screws
    • Re-install the rubber feet, you might want to put a bit of glue on these to keep them on when moving around
Robust
688 İtibar
3 adet Kılavuz yazıldı
Ekip
CV22 CV22 üyesi
Community
1 Üye
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 77
Her zaman: 240
