Ana içeriğe geç
  1. Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
    • Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
  2. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector.
    • Remove the front of the phone, disconnecting the LED connector.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove the 5 screws (Phillips #0) on the black support.
    • Remove the 5 screws (Phillips #0) on the black support.
    • Remove the black support.
  5. remove the 3 screws (Phillips #0) supporting the PCB.
    • remove the 3 screws (Phillips #0) supporting the PCB.
    • Disconnect the antenna on the right.
    • Disconnect the ZIF connector on the left.
    • Disconnect the ZIF connector at the top.
    • Disconnect the two connectors (battery) at the bottom.
  6. Withdraw the jammed SIM card. Withdraw the jammed SIM card.
    • Withdraw the jammed SIM card.
Sonuç
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Steve Muller
178 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 5
Son 30 Gün: 18
Her zaman: 147
