Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. EasyNote TK87-JO-050PL cihazınızı onarmak için, servis kılavuzumuzu kullanın.
      • Unplug your device and take out the battery
      • Avoid leaving the battery in unless you want to get shocked
      • Slide the locked switch to the unlock position.
      FixBot'a Sor
      Yorum Ekle
      • Unscrew all screws on the main body. NOT IN THE BATTERY COMPARTMENT
      • Keep the screws in a small bag or container with separate compartments for reassembly
      FixBot'a Sor
      Yorum Ekle
      • Remove the screws from the HDD and RAM compartment
      • Then remove the cover for the compartment, and use a pry tool if necessary
      FixBot'a Sor
      Yorum Ekle
    1. Packard Bell EasyNote TK87-JO-050PL Teardown, WIFI Module: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use some tweezers to remove both the black and white cable connecting to the wifi module, and wiggle them back and forth if needed. The cables connect upwards so don't move them towards the sides only rotate if wiggling
      • Don't use excessive force, they should just slide out.
      • To finish with the wifi module just unscrew the 1 screw located on the module, then pull it out.
      • If you can't get it out, then leave it in it shouldn't get in our way
      FixBot'a Sor
      Yorum Ekle
      • Remove all screws in the HDD&RAM compartment and all screws in the battery compartment
      • Don't touch the screws on the HDD itself
      FixBot'a Sor
      Yorum Ekle
    2. Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the keyboard: adım 6, 1 resimden 1.
      • There are little clips peppered along to top of the keyboard push them in then use a pry tool to keep the keyboard up.
      • Lift up the keyboard and disconnect the ribbon cable
      • And, TaDa! You removed the keyboard and got so far into this teardown, there's not a lot to go so keep going!
      FixBot'a Sor
      Yorum Ekle
    3. Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the top main body: adım 7, 3 resimden 1. Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the top main body: adım 7, 3 resimden 2. Packard Bell EasyNote TK87-JO-050PL Teardown, Removing the top main body: adım 7, 3 resimden 3.
      • Remove all screws labelled "5L" and keep them seperate
      • Use a pry tool along the edges to remove the top main body
      • Make sure to disconnect the ribbon cables and connector shown
      FixBot'a Sor
      Yorum Ekle
Ethernal Alchemist
242 İtibar
1 Kılavuz yazıldı
5Kılavuz Yorumları
Not doing to help me
Can you help by another system
Star Tesfamikael - Yanıt Paylaş
Battery not charging
Edivier Mna - Yanıt Paylaş
My Computer's Battery is not charging.
When I use other changer, it's working on
Mon ordinateur ne s'allume plus
Mbayediaye Diallo - Yanıt Paylaş
Ben archil Kanda - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 74
Her zaman: 1,659
