Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Panasonic RZ-S50W (Japan) Bluetooth Headphones cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown, Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 1, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown, Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 1, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown, Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 1, 3 resimden 3.
    • Features:
    • Exceptional Sound and Noise Cancellation. Multiple MEMS microphones
    • Optimum Sound Isolation
    • Strong, Stable Connection
    • High-Quality Calling Sound
    • Approximately, 6 hours playback, and up to 20 Hours of use with charger
    • Bluetooth® 5.0
    • Capacitive touch sensor control
  2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 2, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 2, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 2, 3 resimden 3.
    • What is in the box
    • Headphones / Charging Case
    • USB 'C' Cable
    • Headphone rubber tips for different sizes of ears
    • User's Manual
  3. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 3, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 3, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 3, 3 resimden 3.
    • Charging case with headphones
    • Close up view of headphones
  4. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 4, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 4, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 4, 3 resimden 3.
    • Side views of Headphone
    • MEMS Microphones
    • Speaker Spatial Vent Port
    • Speaker Sound Port
    • Speaker Vent
    • USB Interface
    • Charger Interface
    • Vent Port
  5. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 5, 1 resimden 1.
    • View of Headphone with rubber ear piece [cap] removed
    • Vent Port
  6. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 6, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 6, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 6, 3 resimden 3.
    • Since the Panasonic Headphone enclosure is glued together, the only way in was to cut into the headphone.
    • This is a destructive teardown
    • A Razsor Knife was use to cut into the Panasonic headphone along the seam in the headphone. Then a Jimmy Tool was used to open up the headphone
    • Once opened, we get our first look at the inside of the headphone
  7. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 7, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 7, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Opening up the headphone, we can see the main PCB, Battery, Speaker, etc. Tweezers and a Pick Tool were used to removed the electronics from the enclosure
    • Double sided foam tape was used to hold the main the PCB to the Battery and to the Touch Sensor / Antenna PCB. This foam tape had to be cut free. Then Denatured Alcohol was used to remove the foam tape glue from the PCBs and Battery
    • Battery
    • Main PCB
    • Speaker Area
    • Touch Sensor and Antenna
    • Double Sided Foam Tape
  8. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 8, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 8, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 8, 3 resimden 3.
    • At first, I wasn't sure about the solder balls. Then I realized they are used to anchor the USB and Power Interface pins on the outside of the Headphone to the internal circuit board.
    • I had to used a soldering iron to remove the solder balls, so that the internal interface circuit board could be removed. I had to also remove solder from the speaker wires to free up the internal circuit board.
    • The internal circuit board was also attached a MEMS Microphone that appeared to be monitoring the Speaker Chamber of the Headphone, since it was faced in. I had to remove the outside panel with 'R' on it with a Razor Knife to free the MEMS Microphone. Once the MEMS Microphone was freed, the interface circuit board could be pulled out
    • USB and Power (Charger) Interface
    • MEMS Microphone
    • Sound Ports
    • Speaker Wires
    • Internal Circuit Board that interface Power and USB to the Headphones
  9. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 9, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 9, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 9, 3 resimden 3.
    • There was not much to see on the internal interface board. The was one IC component that could not be crossed. If you happen to know the component, please leave a comment below
    • Unknown Component
  10. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 10, 2 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 10, 2 resimden 2.
    • Full Sensor Flex/Charging PCB IC Identification:
    • You may need to enlarge the picture to view the text.
  11. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 11, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 11, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 11, 3 resimden 3.
    • Next the Speaker sound chamber cover was removed with the use of a Pick Tool and Tweezers. A Razor Knife was used to cut the glue holding the speak in place
    • The speaker had no identifiable markings
    • With Speaker removed, we can see the sound chamber and sound ports
  12. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 12, 2 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 12, 2 resimden 2.
  13. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 13, 2 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 13, 2 resimden 2.
    • Closeup view of the Antenna/Touch Sensor side of the Main PCB
    • DSP Group - C2A1A Hybrid Active Noise Cancellation (ANC) Codec and Audio Digital Signal Processor (DSP)
    • 651DF1M9 - Could not cross part number, but during a web search found out that it may be an integrated battery management IC
    • W25Q32JWUUIMTR- SPI FLASH 32Mb
    • MEMS Microphone Port
  14. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 14, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 14, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 14, 3 resimden 3.
    • Closeup view of some of the components on the Antenna/Touch Sensor side of the Main PCB
  15. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 15, 2 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 15, 2 resimden 2.
    • Battery side close up view of the Main PCB
    • AIROHA AB1552 - ARM Cortex M4/Bluetooth 5.0 Dual Mode
    • 927 MPS1 MEMS Microphone. The Headphone uses three MEMS microphones with this part number
    • Could not cross the part number. If you know the part, please leave a comment below. The 2D bar code on the part reads as STM927352NH2S011
    • Crystal Oscillator
    • Unknown component. Labelled B2A. Please leave a comment if you happen to know this component
    • Unknown component. Labelled SV4CP 240. Please leave a comment if you happen to know this component. Separated from PCB during teardown
  16. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 16, 3 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 16, 3 resimden 2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 16, 3 resimden 3.
    • Closeup view of some of the components on the Battery side of the Main PCB
    • 927 MPS1 MEMS Microphone. The Headphone uses three of these MEMS microphones
    • Unknown component. Labelled B2A. Please leave a comment if you happen to know this componentNew line.
  17. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 17, 2 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 17, 2 resimden 2.
    • Closeup view of top and bottom side of the Touch Sensor Flex PCB and PCB Antenna
  18. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 18, 2 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 18, 2 resimden 2.
    • Full Main PCB IC Identification:
  19. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 19, 1 resimden 1.
    • Predicted Block Diagram of the Panasonic RZ-S50W Bluetooth Headphones:
  20. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 20, 2 resimden 1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: adım 20, 2 resimden 2.
    • Teardown Exploded View of the Panasonic Headphone
Robert Shuler
3.549 İtibar
11 adet Kılavuz yazıldı
3Kılavuz Yorumları
If you can, can you post the teardown of the charging case too?
CChin - Yanıt
Dong a web search, I believe the glue removed from the speaker was a silicone dome used to help compress sound waves?
Moe Moe's - Yanıt
yes second the charging case!
Benjamin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 2,640
