Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Philips Bluetooth adapter AEA2700 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: adım 1, 3 resimden 1. Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: adım 1, 3 resimden 2. Philips Bluetooth adapter AEA2700 Teardown, Philips Bluetooth adapter AEA2700 Teardown: adım 1, 3 resimden 3.
    • here you can see the view from the top, the bottom and the backface - device is really tiny: only 7,5cm in diameter!
  2. Philips Bluetooth adapter AEA2700 Teardown: adım 2, 2 resimden 1. Philips Bluetooth adapter AEA2700 Teardown: adım 2, 2 resimden 2.
    • Remove 2 of the rubbers on the bottom side - you'll find 2 screws afterwards>> unscrew them ;)
  3. Philips Bluetooth adapter AEA2700 Teardown: adım 3, 1 resimden 1.
    • now simply remove the top cover.
  4. Philips Bluetooth adapter AEA2700 Teardown: adım 4, 1 resimden 1.
    • there's only one external component connected by cable: the NFC tag
    • it's easily possible to remove the circuit
    • lift it on the front side of the device
    • and pull it this direction - it helps to push at the cinch connector!
  5. Philips Bluetooth adapter AEA2700 Teardown: adım 5, 2 resimden 1. Philips Bluetooth adapter AEA2700 Teardown: adım 5, 2 resimden 2.
    • Front- and backview of the circuit
  6. Philips Bluetooth adapter AEA2700 Teardown: adım 6, 1 resimden 1.
    • when reassembling take care to stick the NFC tag to the correct location in the cover
RFischer
265 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Hello. Is there any way to use this device in a car through an adapter or modification?
Fabio Passarelli - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 3,975
