Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. PlayStation Camera cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. PlayStation 4 Camera Teardown, PlayStation 4 Camera Teardown: adım 1, 3 resimden 1. PlayStation 4 Camera Teardown, PlayStation 4 Camera Teardown: adım 1, 3 resimden 2. PlayStation 4 Camera Teardown, PlayStation 4 Camera Teardown: adım 1, 3 resimden 3.
    • There are two PH0 Screws in the socket which hold the cable.
    • Unscrew two PH0 Screws and pull off the cable holder.
  2. PlayStation 4 Camera Teardown: adım 2, 3 resimden 1. PlayStation 4 Camera Teardown: adım 2, 3 resimden 2. PlayStation 4 Camera Teardown: adım 2, 3 resimden 3.
    • The next two PH0 Screws are located BEHIND the two polycarbonate-plates of the two camera-lenses. Take a sharp tweezer and stab under that plate. The plates are glued with a sticky tape to the housing. These plates are very fragile and will break if handled incautious.
  3. PlayStation 4 Camera Teardown: adım 3, 1 resimden 1.
    • There is one more PH0 screw to remove. This one is behind the other lens.
    • This was the easy part.
  4. PlayStation 4 Camera Teardown: adım 4, 3 resimden 1. PlayStation 4 Camera Teardown: adım 4, 3 resimden 2. PlayStation 4 Camera Teardown: adım 4, 3 resimden 3.
    • There are many clips in there.
  5. PlayStation 4 Camera Teardown: adım 5, 2 resimden 1. PlayStation 4 Camera Teardown: adım 5, 2 resimden 2.
    • Encore two photos where to locate these nasty clips
  6. PlayStation 4 Camera Teardown: adım 6, 3 resimden 1. PlayStation 4 Camera Teardown: adım 6, 3 resimden 2. PlayStation 4 Camera Teardown: adım 6, 3 resimden 3.
    • The other half of the housing is attached to a solid U-Frame with the electronics.
    • There are four silver screws, PH0.
    • Four microphones, two with black/yellow cables and two with black/red wiring.
  7. PlayStation 4 Camera Teardown: adım 7, 2 resimden 1. PlayStation 4 Camera Teardown: adım 7, 2 resimden 2.
    • The backside of the U-frame. The cable is not soldered, there is a plug.
    • Detail of the plug.
    Whats the make of the cable.. What do I search for in order to buy a new one
    Chris - Yanıt
  8. PlayStation 4 Camera Teardown: adım 8, 2 resimden 1. PlayStation 4 Camera Teardown: adım 8, 2 resimden 2.
    • 6 PH1 screws. Take a small magnet to hold them.
  9. PlayStation 4 Camera Teardown: adım 9, 2 resimden 1. PlayStation 4 Camera Teardown: adım 9, 2 resimden 2.
    • The connector of the mikrophone-array
  10. PlayStation 4 Camera Teardown: adım 10, 3 resimden 1. PlayStation 4 Camera Teardown: adım 10, 3 resimden 2. PlayStation 4 Camera Teardown: adım 10, 3 resimden 3.
    • The lenses, plastic, glued tight.
    • NOT ADJUSTABLE.
  11. PlayStation 4 Camera Teardown: adım 11, 2 resimden 1. PlayStation 4 Camera Teardown: adım 11, 2 resimden 2.
    • Backside, two small PH0 at each CCD. But the Cameramodules are clued to the board,too - without destruction, you can not open it.
    • I want to save it as spare-part, so i don't want to open it. So here is finito capito. :) Thanks for watching...
  12. PlayStation 4 Camera Teardown: adım 12, 1 resimden 1.
    • Extra: The wiring.
    • It's an USB3 cable without green/white Pimf. There are three SEPARATE ISOLATED metalfoil shields with wire, red-black-power and two Pimf yellow/blue and orange/green. So ja, thats it. Paulaner.
Schwarzstein
2.813 İtibar
13 adet Kılavuz yazıldı
7 Yorum
Only 7 steps? Where is the rest of the teardown? I wanted to see detailed images of the optics.
Alexandru Voda - Yanıt
Ja, okay, i made some pictures for you. The optics are in Step 10.
Enjoy.
Freundliche Grüsse. :)
Schwarzstein - Yanıt
Does anyone think it would be possible to cut the wires from two cameras and splice the wires together and put the power on a A/B rocker switch to switch between two cameras?
Dan Schultz - Yanıt
Great job, congrats. Do you have also for the other version of ps4 camera same as this one? BR.
Cosmin - Yanıt
I'm wondering if it can even be spliced or soldered back together and actually work
bhee81 - Yanıt
Hi,i want to take out 2 microfons from inside a camera,and to use that microfones to solder on a ps4 wired microfone,is it possible?Thanks
vlamilj - Yanıt
What's the name of this USB cable? I need to replace mine…
Vicente Orlando - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 64
Her zaman: 12,328
