Giriş
This guide shows you how to completely disassemble your camera.
Neye ihtiyacın var
Open the flash/lens compartment of the Polaroid camera to a 30 degree angle with the horizontal.
Open the battery/ cartridge compartment fully.
My film door latch came off the camera and I can’t get the film door open ? Help.
To remove the back of the camera, you have to find the tabs located near the hinges of the battery and film compartment.
Using a screw driver, pry the tabs of the outer case away from the metal frame.
Once the tabs are removed slide the metal frame forward.
Follow the metal band from the flash compartment to the brass tab.
Unhook the wire on the left of the brass tab.
Remove the metal band from behind the brass clip.
Set the now detached flash compartment to the side.
Pull the brass tab up and out like the first one and remove the uncovered wire.
10 Yorum
Is it possible to remove and change the camera straps for this camera?
Yes, after step 8 you will have the back case free then in the inside you will see the latches of the plastic plate that holds the strap, pry them carefully are 6, 2 on each side and 2 in the middle, in the middle of doing it myself have stopped since was no need for that so cannot tell you more.
RAW Fish: Get a terminal driver or other thin device, and wedge it where you can see a line between the outer casing and front panel (where it says “Polaroid” with the rainbow logo). This will need a bit of brute force, but you will be able to seperate a right-angle of outer casing, from the back of the flash, and another right angled bit full of electrics and the front panel. DO NOT touch any of this electrical gubbins - discharging the capacitor through your fingers will HURT. From here you can take out the circuit board and do with it what you wish.
Ariane N -
Hi ! Thanks for your article ! I just bought a Barbie polaroid 600 ;) but unfortunately the flat wire between the camera the flash is disconnected (it dangles from the camera). I managed to remove the flash, that is no longer connected. Do you know how can I open the flash part to reconnect the wires ? Thanks ;)
Is it possible to reassembly the camera after the teardown?
I just got a cámara however the button for the flash or picture does not work is there a way to repair it ?
I have a question are all of the gear supposed to spin smoothly? Or with slight pressure my buck black vision hear on the right side is not moving it on movies when the little silver one on its side moves
On step 20, the spring thing, does anyone know its dimensions or where i can buy it? Its missing from my polaroid cam that doesnt work.
