Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Table Lamp cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Portable Luminaries Lamp Teardown, Portable Luminaries Lamp Teardown: adım 1, 1 resimden 1.
    • The attached picture displays the lamp before the teardown.
  2. Portable Luminaries Lamp Teardown: adım 2, 1 resimden 1.
    • Remove the power cord from the wall socket outlet
    • Make sure to follow this step. There may be a danger of severe electric shock if you proceed to tear down the device without removing the plug
  3. Portable Luminaries Lamp Teardown: adım 3, 2 resimden 1. Portable Luminaries Lamp Teardown: adım 3, 2 resimden 2.
    • Place the lamp gently on its side on a flat surface
    • Twist the lightbulb counter-clockwise to remove it from the lamp's head.
    • After lightbulb removal, the component attaching the lightbulb and lamp's head is exposed.
  4. Portable Luminaries Lamp Teardown: adım 4, 2 resimden 1. Portable Luminaries Lamp Teardown: adım 4, 2 resimden 2.
    • Next, the light bulb housing can be detached from the lamp head
    • Using the Philips screw driver, unscrew the two 5mm diameter screws within the light bulb housing
  5. Portable Luminaries Lamp Teardown: adım 5, 2 resimden 1. Portable Luminaries Lamp Teardown: adım 5, 2 resimden 2.
    • Keep the lamp on its side
    • The bottom is now exposed and two screws are visible
    • Using the Philips Screwdriver, unscrew the two 7mm gold screws from the bottom of the base
  6. Portable Luminaries Lamp Teardown: adım 6, 2 resimden 1. Portable Luminaries Lamp Teardown: adım 6, 2 resimden 2.
    • Once the screws attached to the base are removed, the base's bottom lid detaches from the lamp.
    • Within the base resides two components: the lamp's weight and the switch.
    • The weight sits on the bottom base lid, so it separates without the use of additional tools.
  7. Portable Luminaries Lamp Teardown: adım 7, 1 resimden 1.
    • The white container holding the switch does not need tools for opening.
    • The switch container is clipped shut and opens by unlatching the tab
Brenden
56 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,663
