Bu Teardown'da Kullanılan Aletler
Giriş
The infamous Power Mac G4 Cube, Apple's original failed attempt at a compact G4-based Macintosh. Released in 2000 at a cost of $1599, the Cube was considered too expensive, and too slow. The Cube, unlike most computers, uses passive cooling, which means no fan. While quiet, it was a big mistake on Apple's part, because the G4 processors run very hot!
The Cube boasted a 450MHz or 500Mhz G4 CPU; not particularly fast given its 1Ghz Pentium III contemporary. The Cube is virtually silent, aside from the original 5400 RPM hard-drives. After a single year of production, Apple put the cube "on ice”. But it lives on in infamy as a popular candidate for Macquariums and as a coveted design piece. An internal fan hookup in the form of a 12V, 2-pin connector is available but was never utilised by Apple. If you want, you can buy a fan, connect it, and figure out a place to fit it; this is a popular mod to cool overheating Cubes.
Conceptually, it was replaced by the Mac Mini in 2005, 5 years later.
Removing the Ram
Start by fliping the cube so that the side with the graphics card is facing you, you may want to push the handle back in.
There are 3 RAM Slots, they are Standard PC100 Ram. The cube can support up to 1.5GB of ram, that's a 512MB Stick In All 3 Slots.
Remove the ram, just like any other kind of ram.
Removing the AGP Riser card
Pull the card out of the PCI Socket, and no, unfortunately, you can't use this to put an AGP card in a PCI slot in a PC.
Once the card is free, mind the 3 cables attached to it, remove these 2 cables first.
The third cable is glued to the AGP board, unplug it from the logic board instead.
Removing the Voltage Regulator Module.
This board is called the DC/DC board, or the Voltage Regulator Module. It takes the power from the power brick and regulates the power to different components of the Cube.
First, disconnect the power connector.
Then release the white clip on the connector socket, which is accessed from the side of the core.
With a little persuasion, the board comes out of it's socket(it's hard to show how the board comes out, but in person, it's pretty self explanatory)
The Logic Board
Unfortunately, this as far as I am going to dissect my cube, partially because I still use it frequently, but here is an overview of the cube.
450Mhz or 500Mhz PowerPC G4 Processor
Shipped with 64MB ram, supports up to 1.5GB of PC100 or PC133
One PCI Slot(Converted to AGP via adaptor)
No Onboard Audio.(Unfortunately)
7 Yorum
This is great! What a beautiful machine that was.
Awesome teardown, Chris! Thanks for posting it.
Worst pictures I've seen in a teardown in a long time…
