Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Power Macintosh 8600(250) cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Power Macintosh 8600(250) Teardown, Power Macintosh 8600(250) Teardown: adım 1, 1 resimden 1.
    • There she is! i'm missing the bezel around the floppy drive :(
  2. Power Macintosh 8600(250) Teardown: adım 2, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 2, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 2, 3 resimden 3.
    • Start by pressing the big green button. And pulling the door away and up from the computer.
    • And on the Back of the door is the fan.
  3. Power Macintosh 8600(250) Teardown: adım 3, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 3, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 3, 3 resimden 3.
    • Now it's best to lay the computer flat.
    • And to flip up the tabs, grab the handle and open.
  4. Power Macintosh 8600(250) Teardown: adım 4, 1 resimden 1.
    • The innards, motherboard, daughter board, RAM and so fourth.
  5. Power Macintosh 8600(250) Teardown: adım 5, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 5, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 5, 3 resimden 3.
    • Now the speaker
    • Remove the speaker wires
    • And the fan wires from the motherboard
    • Push in the two plastic tabs on either side and lift the speaker up and out.
  6. Power Macintosh 8600(250) Teardown: adım 6, 2 resimden 1. Power Macintosh 8600(250) Teardown: adım 6, 2 resimden 2.
    • The PRAM battery!
    • Remove the housing by pulling it out and then take the battery out.
  7. Power Macintosh 8600(250) Teardown: adım 7, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 7, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 7, 3 resimden 3.
    • The processor, firmly grasp and pull out.
    • Remove the 4 #1 Phillips screws
    • And push the 4 tabs off of the board
  8. Power Macintosh 8600(250) Teardown: adım 8, 1 resimden 1.
    • Any video card or usb card, mine happens to be an ethernet 10/100 card.
    • Unfortunately there are 6 spaces but only 3 slots on the motherboard :(
    • Remove the #1 Phillips screw and pull the card out.
  9. Power Macintosh 8600(250) Teardown: adım 9, 1 resimden 1.
    • RAM and VRAM slots!
  10. Power Macintosh 8600(250) Teardown: adım 10, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 10, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 10, 3 resimden 3.
    • Moving on to the CD, ZIP, and Floppy drives (best to close computer now)
    • Remove the bezels and if I had the top one remove that too.
    • Remove the 6 phillips screws and pull the metal frames out.
  11. Power Macintosh 8600(250) Teardown: adım 11, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 11, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 11, 3 resimden 3.
    • Remove the data and power cables
    • Pay special attention to this one, it has a clip on it, it helps to use a flathead or a spudger.
    • Pull the drives out of the bay.
  12. Power Macintosh 8600(250) Teardown: adım 12, 2 resimden 1. Power Macintosh 8600(250) Teardown: adım 12, 2 resimden 2.
    • Now the hard drive.
    • Remove the two phillips screws
    • And the data and power cables (might help to remove them as you pull the drive out)
  13. Power Macintosh 8600(250) Teardown: adım 13, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 13, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 13, 3 resimden 3.
    • The power source
    • Remove the two connectors
    • There is a clip holding the wires in place. Separate and remove the wires. (both sets)
  14. Power Macintosh 8600(250) Teardown: adım 14, 3 resimden 1. Power Macintosh 8600(250) Teardown: adım 14, 3 resimden 2. Power Macintosh 8600(250) Teardown: adım 14, 3 resimden 3.
    • Now remove the 4 phillips screws (it's best to start with the bottom two)
    • And pull it out while de-threading the wires.
Plague
181 İtibar
1 Kılavuz yazıldı
Bir Yorum
Nice. I got a beige G3 300 Mhz, the case is similar. Maybe I could also make a teardown.
Nicolas Zbinden - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 15,282
