Giriş
The Powermac G3, apple's G3 Powerhouse. This computer Introduced the design that stuck until the powermac G5, but this computer started the "Handle's" Trend, every powermac G3, G4, G5, and Mac Pro now has handles. This computer boasted a 350Mhz, 400Mhz, and 450Mhz PowerPC G3 CPU. This cpu is incredibly easy to overclock, due to it's "clock-config" jumper convienlently located next to the CPU(though i don't encourage overclocking). This computer had blue plastic, resembelent of the iMac G3's and the iBook G3 Clamshells. It would have been great if Apple had made this is other colors, like the imac, a lime green Powermac G3 would rock!
Neye ihtiyacın var
RAM
The PowerMac G3 B&W supports up to 1GB of PC100 RAM.
It has 4 RAM slots for an optimal configuration of 4x 256MB DIMM's.
khlae kullanıcısından alıntı:
the b&w g3 supports up to 1gb pc100 ram.
Khale's right- my G3 currently has 1GB.
Graphics Card:
The Powermac G3 Came Standard With A 16MB ATI 3D Rage PCI Mac Edition Card, there are only a few available upgrade cards.
Start By Removing this Screw.
Once that's done, pull the card out.
Sorry Guys, Regular PCI Cards Won't work here, only Mac Edition PCI-Compatible Cards, and this card won't work in a PC, Also, graphics cards only work in the first slot, the other 4 PCI Slots won't support graphics cards.
Then remove this screw too.
Then lift the module out, there is a connector underneath it, to be careful while doing this.
Then we can move on.
Removing the power supply
Disconnect the power connector from the logic board (this looks alot like a standard ATX connector. The lone difference is that the wire which supplies -5V on an ATX supply [pin 18] becomes a ground wire in the B&W G3. If you just plug in an ATX supply without any modifications, you'll short out its -5V output. )
There is a 4-Pin Cable connected to the front panel box, remove it.
Disconnect the internal fan cable.
The Fan Connector
Then Route all of the cables up through the case to the level of the power supply.
Remove these phillips screws.
Now, you can slide the power supply towards you, and remove it.
Sorry, but my camera battery died, I will post photos on how to remove the logic board after I take them
Sorry, but you didn’t mention to remove 2 hex screws from the back of the case on both sides of the power connectors!
6 Yorum
I dub thee Chris Green, The Teardown Machine. Good work!
Actually, I have to call you on your comment about the PCI slots. I used to run a dual monitor setup on my B&W G3. I had an ATI Xclaim VR 128 installed in the second slot, giving me a second graphics card, with a TV tuner/AV input. It worked perfectly. The Tuner's software never made the transition to Mac OS X, sadly, so i had to boot into OS 9 any time I wanted to do recording, but it most definitely worked.
Yep, the pci slots will absolutely run graphics cards. If they didn't they wouldn't be pci slots. I also ran graphics cards off of them. However, they run like crud compared to the 66mhz slot, since they are shared and 33mhz. You can also run standard PC graphics cards, as long as there is a mac compatible rom that you can flash onto it. Reflashed cards used to sell on ebay for real good prices.
khlae -
Nice teardown.
