Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Powerbeats Pro cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    Son Düşünceler
    • The battery is a fairly common button-cell, and is only lightly soldered in place, meaning battery swaps are technically possible with the right tools.
    • The earbuds’ opening procedure is not totally destructive per se, but it will likely lead to at least some cosmetic damage.
    • The earbuds’ internal circuitry is all connected with fragile ribbon cables that do not detach, so a full disassembly can only be accomplished destructively.
    • The charging case is a nightmarish bucket of glue, making potential battery replacements unnecessarily difficult and destructive.
    Onarılabilirlik Puanı
    Onarılabilirlik 10 üzerinden 1
    (10 en kolay onarılabileni)
Taylor Dixon
67.033 İtibar
94 adet Kılavuz yazıldı
7 Yorum
Review missed the debris screens in the ear tubes which often get damaged. How to replace possibly.
chronus - Yanıt
I can’t connect them when they are in the case are connect if I take them out of the case they disconnected. and it says they need to be on and on range help please
Eduardo Gaspar - Yanıt
So far it is just the case for mine that seems broken - It won’t charge the buds properly. I really don’t mind cosmetic damage if I can replace the case’s battery (assuming that is the culprit). Where might I get a replacement battery? Also, if I used enough care, could I not just cut into the case closer to the battery to get at it from underneath?
Tom Hernandez - Yanıt
I pushed my mesh in on one of my pods. Is there any fix to just bring it back?
AuxCord Broke - Yanıt
My volume button is stuck. It will turn up and change songs. However I can not turn down the volume at all. Can I fix it somehow?
Lisa Nikodym - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 119
Son 30 gün: 485
Her zaman: 39,494
