Neye ihtiyacın var
The head is attached with a machine screw and a split washer to make the head hold its position.
If the head slips sometimes the helical split washer can be bent out or replaced.
Spring: holds ball bearing against pawl
Ball bearing: holds pawl in its position
Pawl: allows gear/tang to rotate in only one direction
Gear/Tang: part that rotates
Lever: selects the pawls position and what direction the gear turns
