Giriş
This is my tear down of the Razer Blade 14. I haven't yet seen anyone dismantle this notebook so i decided to give it as try and went as far as I felt comfortable going.
Bu teardown bir tamir kılavuzu değildir. Razer Blade 14" (2013) cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. The thin and sleek gaming Notebook from Razer. The thin and sleek gaming Notebook from Razer.
    • The thin and sleek gaming Notebook from Razer.
  2. Remove the 10 Screws holding the back Cover on to reveal the mainboard. DDR3 Ram chips CPU Chipset
    • Remove the 10 Screws holding the back Cover on to reveal the mainboard.
    • DDR3 Ram chips
    • CPU Chipset
    • Liteon 256gb SSD (factory installed)
    • Factory WLAN/BT card
    • Battery
    • Aftermarket MSata SSD (installation screw not included)
  3. Removing the Battery Removing the Battery Removing the Battery
    • Removing the Battery
  4. Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode. Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode. Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode.
    • Apparently this notebook was named even before i got it! In my use this battery will last through 4-5 hours of movies on power saver mode.
  5. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  6. Removing the Speakers. Removing the Speakers.
    • Removing the Speakers.
  7. The original mSATA SSD. (the secondary seen earlier was added by myself. The original mSATA SSD. (the secondary seen earlier was added by myself. The original mSATA SSD. (the secondary seen earlier was added by myself.
    • The original mSATA SSD. (the secondary seen earlier was added by myself.
  8. Removing the fans. Removing the fans. Removing the fans.
    • Removing the fans.
  9. Removing the heatsinks. Removing the heatsinks. Removing the heatsinks.
    • Removing the heatsinks.
  10. Removing the mainboard. Removing the mainboard. Removing the mainboard.
    • Removing the mainboard.
  11. This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable. This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable. This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable.
    • This is the end of the teardown. anything past this point would likely cause damage to the notebook and as i intend to continue using it, this would be undesirable. Just one thing i noticed, that there is an debug ribbon cable plug left on the board, another thing, the power plug is replaceable.
tallme15
794 İtibar
2 adet Kılavuz yazıldı
41 Yorum
Great work, very, very professional ! And thanks, was really curious to see how one looks on the inside !
Darie H - Yanıt
Awsome Teardown! Thanks A bunch!
my91331 - Yanıt
Thanks a bunch everyone! With all the recognition I've gotten with this teardown I decided I would redo it with pictures taken on a proper DSLR and more of them and more indepth captions for the individual steps, I may even make some replacement guides!
tallme15 - Yanıt
Is that a second mSATA slot I see on the left side of the motherboard underneath the large ribbon cable?
Bryce - Yanıt
Indeed it is! it functions too, the stock is beneath the cable, the unpopulated is the exposed one, that i had installed an Mushkin atlas in and started using without a hitch.
tallme15 -
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 Gün: 37
Son 30 Gün: 167
Her zaman: 52,987
