Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. RedOctane X-Plorer cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. RedOctane X-Plorer Teardown, Case: adım 1, 1 resimden 1.
    • Remove all 16 #10-torx screws from the back side of the case.
    • Gently separate the case pieces.
    • A strong magnet helps greatly when taking out the screws.
    • Keep in mind when resembling, the case is plastic so, don't tighten the screws too tight.
  2. RedOctane X-Plorer Teardown, Neck: adım 2, 1 resimden 1.
    • Unscrew the 4 #10-torx screws.
  3. RedOctane X-Plorer Teardown, Colored Keys: adım 3, 3 resimden 1. RedOctane X-Plorer Teardown, Colored Keys: adım 3, 3 resimden 2. RedOctane X-Plorer Teardown, Colored Keys: adım 3, 3 resimden 3.
    • Unscrew the 2 Philips head screws
    • Peel off the pads.
    • Push the colored keys out from the other side.
  4. RedOctane X-Plorer Teardown, Strum Bar: adım 4, 3 resimden 1. RedOctane X-Plorer Teardown, Strum Bar: adım 4, 3 resimden 2. RedOctane X-Plorer Teardown, Strum Bar: adım 4, 3 resimden 3.
    • Unscrew the red screws and pull the board out.
    • Then, unscrew the blue screws
    • Pull the bracket things off.
    • Pull out the pin.
  5. RedOctane X-Plorer Teardown, Unused port: adım 5, 1 resimden 1.
    • Unscrew the 4 Philips head screws.
  6. RedOctane X-Plorer Teardown, Aux Port: adım 6, 1 resimden 1.
    • Unscrew these 2 Philips head screws.
  7. RedOctane X-Plorer Teardown, Whammy Bar: adım 7, 2 resimden 1. RedOctane X-Plorer Teardown, Whammy Bar: adım 7, 2 resimden 2.
    • Push from the other side until it comes out.
    • Take the spring off with the connector
  8. RedOctane X-Plorer Teardown, Motherboard: adım 8, 2 resimden 1. RedOctane X-Plorer Teardown, Motherboard: adım 8, 2 resimden 2.
    • Peel off the contact pads.
Jackson Poer
671 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
"unused port" is for a footpedal switch,not positive but believe all GH style guitars have one
Valden Tharbosen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 68
Her zaman: 3,356
