Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Roborock S7 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Roborock S7: Teardown, Top cover: adım 1, 2 resimden 1. Roborock S7: Teardown, Top cover: adım 1, 2 resimden 2.
    • Begin by removing the front half of the top cover.
    • It is held on by relatively loose latches. They will come free with some force.
    • Do not bend the plastic cover too much. It has some flexibility, but if bent too much, it could deform or snap.
    • Continue by removing the back half of the top cover.
    • Once removing the screws and the plastic bits, it will just pop out.
  2. Roborock S7: Teardown, LiDAR: adım 2, 3 resimden 1. Roborock S7: Teardown, LiDAR: adım 2, 3 resimden 2. Roborock S7: Teardown, LiDAR: adım 2, 3 resimden 3.
    • Remove the rubber caps covering the 2 screws.
    • Remove the screws.
    • Remove the LiDAR cage.
    • Remove the LiDAR screws, then remove the LiDAR.
    • Based on the version of the robot, you might see one of 3 different iterations of the LiDAR. One, that is noticeably smaller, is connected via cable, whereas the other 2 are simply connected by a connector.
  3. Roborock S7: Teardown, Bottom cover, battery and bumper: adım 3, 3 resimden 1. Roborock S7: Teardown, Bottom cover, battery and bumper: adım 3, 3 resimden 2. Roborock S7: Teardown, Bottom cover, battery and bumper: adım 3, 3 resimden 3.
    • Remove the 5 screws and side brush, then remove the bottom panel.
    • Remove the battery. Pull it up and over from left to right, then disconnect the connector.
    • Be careful with the connector. I've had cases where people had torn them off by yanking at the cable instead of pressing on and pulling the connector.
    • Remove the marked screws, then remove the top cover of the bumper, then the bumper itself.
  4. Roborock S7: Teardown, Side brush motor and VibraRise lift wire: adım 4, 3 resimden 1. Roborock S7: Teardown, Side brush motor and VibraRise lift wire: adım 4, 3 resimden 2. Roborock S7: Teardown, Side brush motor and VibraRise lift wire: adım 4, 3 resimden 3.
    • Continue by removing the side brush motor.
    • Move further below, then remove the screws. The 2 holes marked by arrows have screws within them. The smaller screws are PH1 and the bigger are PH2. After removing the screws, remove the side panel.
    • Remove the wire from the plastic housing. Angled tweezers recommended.
  5. Roborock S7: Teardown, Check on your feline assistant.: adım 5, 1 resimden 1.
    • Shhh, she's sleeping.
  6. Roborock S7: Teardown, Chassis and main brush: adım 6, 3 resimden 1. Roborock S7: Teardown, Chassis and main brush: adım 6, 3 resimden 2. Roborock S7: Teardown, Chassis and main brush: adım 6, 3 resimden 3.
    • Remove the screws marked in image 1.
    • Now remove the screws in image 2, then remove the main brush assembly. There is no need to remove the brush cover or the brush itself. You simply pull it out.
    • Remove the 2 screws hidden by the main brush assembly.
  7. Roborock S7: Teardown, Latches on the back: adım 7, 2 resimden 1. Roborock S7: Teardown, Latches on the back: adım 7, 2 resimden 2.
    • Unlatch these 2 latches.
  8. Roborock S7: Teardown, Finito: adım 8, 1 resimden 1.
    • And voila, it's open.
DegenFixer
4.537 İtibar
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 156
Son 30 gün: 505
Her zaman: 2,329
