Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Rowenta AC6221 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: adım 1, 3 resimden 1. Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: adım 1, 3 resimden 2. Rowenta AC6221 Teardown, Rowenta AC6221 Teardown: adım 1, 3 resimden 3.
    • The 4.8 Rowenta vacuum can be used for a variety of purposes.
    • It is charged through its pedestal. The power of the pedestal is:
    • Input: 230V - 50 Hz - 7W (AC)
    • Output: 7.5V - 300 mA (DC)
  2. Rowenta AC6221 Teardown: adım 2, 3 resimden 1. Rowenta AC6221 Teardown: adım 2, 3 resimden 2. Rowenta AC6221 Teardown: adım 2, 3 resimden 3.
    • This vacuum has several parts:
    • The tip
    • The reservoir which holds the dust and debris
    • The engine (4.8V)
    • The pedestal
    • The power supply
    • From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
  3. Rowenta AC6221 Teardown: adım 3, 3 resimden 1. Rowenta AC6221 Teardown: adım 3, 3 resimden 2. Rowenta AC6221 Teardown: adım 3, 3 resimden 3.
    • Remove the two outer Philips #00 screws from the bottom of the engine.
    • The back of the circuit board will now be visible.
  4. Rowenta AC6221 Teardown: adım 4, 3 resimden 1. Rowenta AC6221 Teardown: adım 4, 3 resimden 2. Rowenta AC6221 Teardown: adım 4, 3 resimden 3.
    • Remove the two inner screws.
    • Insert a flat screwdriver between the cover and the base of the engine and remove the cover.
    • The wires of the vacuum are now visible.
  5. Rowenta AC6221 Teardown: adım 6, 2 resimden 1. Rowenta AC6221 Teardown: adım 6, 2 resimden 2.
    • The wires connect the charger light, switch,engine, and power wires.
    • The green box labels the engine.
    • The orange box labels one of the four batteries (4*1.2V)
  6. Rowenta AC6221 Teardown: adım 7, 2 resimden 1. Rowenta AC6221 Teardown: adım 7, 2 resimden 2.
    • The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
    • The bottom side shows the tracks that connect the components.
  7. Rowenta AC6221 Teardown: adım 8, 2 resimden 1. Rowenta AC6221 Teardown: adım 8, 2 resimden 2.
    • Remove the screw securing the handle with a screwdriver.
    • Open the handle to see the inside using the flat screwdriver.
    • Warning: The handle is difficult to open
    • Warning: In this procedure, the handle was not opened to keep the vacuum intact.
  8. Rowenta AC6221 Teardown: adım 9, 1 resimden 1.
    • This is the pedestal that will be torn down.
  9. Rowenta AC6221 Teardown: adım 10, 3 resimden 1. Rowenta AC6221 Teardown: adım 10, 3 resimden 2. Rowenta AC6221 Teardown: adım 10, 3 resimden 3.
    • At the bottom of the pedestal, remove the 4 rubber pieces.
    • Note: This step provides access to 4 Philips screws.
    • Remove screws using a screwdriver.
  10. Rowenta AC6221 Teardown: adım 11, 1 resimden 1.
    • Lift the plastic piece carefully from the bottom of the pedestal.
  11. Rowenta AC6221 Teardown: adım 12, 1 resimden 1.
    • Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
    • This completes the vacum cleaner teardown
Bob
760 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
This could use some discussion of how to replace the rechargeable batteries used in portable vacuum cleaners.
Wayne Seltzer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 7,235
