Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Rubik's Cube cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: adım 1, 3 resimden 1. Rubik's Cube Teardown, Rubik's Cube Teardown: adım 1, 3 resimden 2. Rubik's Cube Teardown, Rubik's Cube Teardown: adım 1, 3 resimden 3.
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: adım 2, 2 resimden 1. Rubik's Cube Teardown: adım 2, 2 resimden 2.
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: adım 3, 2 resimden 1. Rubik's Cube Teardown: adım 3, 2 resimden 2.
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
rab777hp
20.333 İtibar
3 adet Kılavuz yazıldı
Ekip
OPEN OPEN üyesi
Community
82 Üyeler
25 adet Kılavuz yazıldı
6 Yorum
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Yanıt
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Yanıt
my middle peices came out cant fix it
jax - Yanıt
can someone tell me how to fix it
jax - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 24,546
