Ana içeriğe geç
Bu teardown bir tamir kılavuzu değildir. Rubik's Cube cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Turn the top row so that each corner is roughly halfway between the sides Push the pieces up until they pop out of the cube, then, slide the rest out Repeat this process until you clear the level
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  3. You should be able to just directly pull out the rest of the blocks, like so And there you have it!
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  4. To reassemble, snap all the pieces back into place, and try not to rotate the faces. It helps to start with the middle pieces first
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
rab777hp
20.675 İtibar
3 adet Kılavuz yazıldı
Takım
OPEN OPEN üyesi
Community
76 Üyeler
15 adet Kılavuz yazıldı
3 Yorum
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Yanıt
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 Gün: 46
Son 30 Gün: 193
Her zaman: 19,421
