Bu Teardown'da Kullanılan Aletler
Ports on the side:
Headphone Jack
SD/SDHC/SDXC card slot
Ports on the Back:
USB 3.0
USB 2.0
HDMI
40W DC in charging port
Time to grab the tools and open the case. Nothing fancy needed here, just a simple phillips screwdriver, a knife and a spudger.
Remove the 5 visible Phillips #0 screws.
Remove the 4 hidden screws under the rubber feet (one under each rubber foot). If you only partially pry up each foot enough to get to the screws, you can reuse the feet without having to re-glue them.
Battery removed, it's now time to remove the screen and pull the main board
Disconnect the 2 antennae lines from the main board
Disconnect the screen cable
Remove the 5 screws holding the main board
Probably a good idea to disconnect the remaining 4 cables as well
Keyboard and trackpad ribbon cables
Audio cable
CMOS Battery Cable
Top of the main board
Samsung Exynos 5250 AEON main proc
SanDisk SDIN7DU2-16G NAND Flash
4 x ELPIDA J2108EDBG-GN-F (4 more on the rear)
MAX 77686 EWE 1237
TPS65090 TI 291
"Servo" dev/debug interface.
Connector for 3G daughterboard.
The Embedded Controller, according to Google's documentation is STM32F100R8, although it is marked as "32F100B6"
Trusted Platform Module, Infineon SLB9635
Not much more on the rear but the rest of RAM
32 Yorum
@Josh Thomas
When re-assembling the chromebook, I have noticed that the factory assembly is done in a different order (and thus the disassembly should be done in a different order as well). Let me explain: there is a small plastic piece, long and low, in the back part of the laptop (where the connectors are). For me, it is 100% clear that this is the latest part in the assembly process at the factory, because of the position of the plastic clicks.
So for disassembly it should be the first part to be removed. It helps a lot removing this part first, in order to avoid any click to be broken.
But prior to modifying the teardown I would like to know if you agree in that this is the correct process (or your opinion).
(BTW I know that Google has posted some disassembly instructions on their chromiumos page, but for me those instructions are not correct as well. Note that the manufacturer is Samsung and not Google, and that's why I'm afraid the instructions are not precise).
Both of my Samsung Chromebooks are on loan to friends, so I will have a hard time verifying your question for a couple of weeks. Please update the teardown as you see fit.
I can always come back and update the photos (or take new ones) if you like, but it will be delayed.
If the part you are referring to covering the screen to body hinge? That part actually doesn't need to be removed at all if you are just digging for internals. The screen can stay connected.
Josh, I've just added the instructions along with some photos. Feel free to delete or modify the steps inserted if you consider so, as the teardown is your property.
All the best!
Jacobo
Awesome! It' not my teardown, it's for the community so any addition is a good one :)
Thanks!
