Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung GT-E2120 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: adım 1, 1 resimden 1.
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: adım 2, 2 resimden 1. Samsung GT-E2120 Teardown: adım 2, 2 resimden 2.
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: adım 3, 2 resimden 1. Samsung GT-E2120 Teardown: adım 3, 2 resimden 2.
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: adım 4, 3 resimden 1. Samsung GT-E2120 Teardown: adım 4, 3 resimden 2. Samsung GT-E2120 Teardown: adım 4, 3 resimden 3.
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: adım 5, 2 resimden 1. Samsung GT-E2120 Teardown: adım 5, 2 resimden 2.
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: adım 6, 1 resimden 1.
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: adım 7, 2 resimden 1. Samsung GT-E2120 Teardown: adım 7, 2 resimden 2.
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: adım 8, 1 resimden 1.
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
Michael C
410 İtibar
1 Kılavuz yazıldı
Ekip
OPEN OPEN üyesi
Community
82 Üyeler
25 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 14,023
