Ana içeriğe geç
Neye ihtiyacın var
Aletler
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy Ace cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    1. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: adım 1, 3 resimden 1. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: adım 1, 3 resimden 2. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: adım 1, 3 resimden 3.
      • Rotate your Phone.
      • Remove the plastic battery door.
      • Remove battery.
      • Unscrew all 7 screws so that the cover can be removed.
      FixBot'a Sor
      Yorum Ekle
    2. Samsung Galaxy Ace Teardown: adım 2, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 2, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 2, 3 resimden 3.
      • With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
      • Make sure your Micro SD card is removed from the device Micro SD card slot.
      • Disconnect the microphone using your fingers, be careful not to do too much pressure.
      FixBot'a Sor
      Yorum Ekle
    3. Samsung Galaxy Ace Teardown: adım 3, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 3, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 3, 3 resimden 3.
      • Disconnect the light sensor and ear piece speaker.To remove this use a plastic tool.
      • Disconnect the volume rocker, be very careful! They are very thin and glued with double-sided tape. If possible, use isesamo or something really thin!
      FixBot'a Sor
      Yorum Ekle
    4. Samsung Galaxy Ace Teardown: adım 4, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 4, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 4, 3 resimden 3.
      • Lift the logic board from the right side, be careful not cause any damage to gently rotate the LCD connector.
      • Now with a plastic tool you can disconnect the LCD connector.
      FixBot'a Sor
      Yorum Ekle
    5. Samsung Galaxy Ace Teardown: adım 5, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 5, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 5, 3 resimden 3.
      • Remove logic board
      • Disconnect speaker and camera with a plastic tool.
      FixBot'a Sor
      Yorum Ekle
    6. Samsung Galaxy Ace Teardown: adım 6, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 6, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 6, 3 resimden 3.
      • Use a plastic tool or something sharp to lift the aluminum protection that serves to fix earpiece speaker and light sensor and remove it.
      • After lifting the connector of the touch screen (black tab), lift the cable carefully!
      FixBot'a Sor
      Yorum Ekle
    7. Samsung Galaxy Ace Teardown: adım 7, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 7, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 7, 3 resimden 3.
      • Press the home button to remove it. (This is not fixed,no material).
      • Heat the glass lens with a hot air gun, a tool insert after "isesamo" and slowly raise it.
      • Remove it.
      FixBot'a Sor
      Yorum Ekle
    8. Samsung Galaxy Ace Teardown: adım 8, 1 resimden 1.
      • Disassembly is finished! To assemble, follow the guide from the end point to the initial.
      FixBot'a Sor
      Yorum Ekle
AndreaBaglione
3.912 İtibar
3 adet Kılavuz yazıldı
3Kılavuz Yorumları
Very helpful, I had to open it all up as shown in photo to get my stuck SIM cards out. Thanks.
Yash J - Yanıt Paylaş
My ace s5830 cant sharging i change ic charge and battary and also can t charging why !
Jaafar Fakih - Yanıt Paylaş
Maybe motherboard or cable is dead?
Paul Richard - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 79
Her zaman: 17,372
