Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy Ace cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: adım 1, 3 resimden 1. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: adım 1, 3 resimden 2. Samsung Galaxy Ace Teardown, Samsung Galaxy Ace Teardown: adım 1, 3 resimden 3.
    • Rotate your Phone.
    • Remove the plastic battery door.
    • Remove battery.
    • Unscrew all 7 screws so that the cover can be removed.
  2. Samsung Galaxy Ace Teardown: adım 2, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 2, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 2, 3 resimden 3.
    • With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
    • Make sure your Micro SD card is removed from the device Micro SD card slot.
    • Disconnect the microphone using your fingers, be careful not to do too much pressure.
  3. Samsung Galaxy Ace Teardown: adım 3, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 3, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 3, 3 resimden 3.
    • Disconnect the light sensor and ear piece speaker.To remove this use a plastic tool.
    • Disconnect the volume rocker, be very careful! They are very thin and glued with double-sided tape. If possible, use isesamo or something really thin!
  4. Samsung Galaxy Ace Teardown: adım 4, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 4, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 4, 3 resimden 3.
    • Lift the logic board from the right side, be careful not cause any damage to gently rotate the LCD connector.
    • Now with a plastic tool you can disconnect the LCD connector.
  5. Samsung Galaxy Ace Teardown: adım 5, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 5, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 5, 3 resimden 3.
    • Remove logic board
    • Disconnect speaker and camera with a plastic tool.
    thx for this step
    Kyle at work - Yanıt
  6. Samsung Galaxy Ace Teardown: adım 6, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 6, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 6, 3 resimden 3.
    • Use a plastic tool or something sharp to lift the aluminum protection that serves to fix earpiece speaker and light sensor and remove it.
    • After lifting the connector of the touch screen (black tab), lift the cable carefully!
  7. Samsung Galaxy Ace Teardown: adım 7, 3 resimden 1. Samsung Galaxy Ace Teardown: adım 7, 3 resimden 2. Samsung Galaxy Ace Teardown: adım 7, 3 resimden 3.
    • Press the home button to remove it. (This is not fixed,no material).
    • Heat the glass lens with a hot air gun, a tool insert after "isesamo" and slowly raise it.
    • Remove it.
  8. Samsung Galaxy Ace Teardown: adım 8, 1 resimden 1.
    • Disassembly is finished! To assemble, follow the guide from the end point to the initial.
AndreaBaglione
3.912 İtibar
3 adet Kılavuz yazıldı
3 Yorum
Very helpful, I had to open it all up as shown in photo to get my stuck SIM cards out. Thanks.
Yash J - Yanıt
My ace s5830 cant sharging i change ic charge and battary and also can t charging why !
Jaafar Fakih - Yanıt
Maybe motherboard or cable is dead?
Paul Richard -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 16,070
