Videoya Genel Bakış
- External assemblies are held together with clips instead of glue, making for a non-destructive entry process.
- Disassembly can be accomplished with common prying tools and a Phillips screwdriver.
- The earbuds use rechargeable coin-cell batteries that are easier than ever to replace.
- Opening procedure is a bit unorthodox, and can cause cosmetic damage to the buds.
- Careful prying is required throughout to separate components without tearing fragile cables or otherwise damaging the buds.
Son Düşünceler
Onarılabilirlik Puanı
7
Onarılabilirlik 10 üzerinden 7
(10 en kolay onarılabileni)
6 Comments
Would be nice if you could ID the rest of the major IC’s too.
Sean Davis - Yanıt
where can I find replacement parts?
Michel - Yanıt
More wireless earbud teardowns, please! I would also like to see the Galaxy Buds+ drivers.
Mike Housholder - Yanıt
possible to swap in a higher capacity battery for the buds+ and the case to increase total usable time in between charging.
K T - Yanıt
https://www.endrich.com/sixcms/media.php...
K T - Yanıt
