Giriş
This is a Teardown of my old broken Samsung Galaxy Pocket (GT-S5300)
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy Pocket (GT-S5300) cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Remove the battery cover Then remove the battery Then remove the battery
    • Remove the battery cover
    • Then remove the battery
  2. Remove all 4 screws Remove all 4 screws
    • Remove all 4 screws
  3. Slide a guitar pick between the sliver bezel and the rear of the phone Slide it all the way around until the rear is loosened from the logic board and screen
    • Slide a guitar pick between the sliver bezel and the rear of the phone
    • Slide it all the way around until the rear is loosened from the logic board and screen
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Remove LCD connector Remove LCD connector
    • Remove LCD connector
  6. Remove logic board from screen by lifting  the logic board up and removing the digitizer connector
    • Remove logic board from screen by lifting the logic board up and removing the digitizer connector
  7. Remove the 5 screws to remove the shield Remove the 5 screws to remove the shield
    • Remove the 5 screws to remove the shield
  8. Remove what seems to be the antenna from the logic board Remove what seems to be the antenna from the logic board Remove what seems to be the antenna from the logic board
    • Remove what seems to be the antenna from the logic board
  9. Slide guitar pick between the digitizer and lcd Make sure not to get under the black adhesive on the back be the digitizer
    • Slide guitar pick between the digitizer and lcd
    • Make sure not to get under the black adhesive on the back be the digitizer
    • At the top of the digitizer there is a circuit be careful up there
  10. So that's my teardown for the Samsung galaxy pocket (GT-S5300)
    • So that's my teardown for the Samsung galaxy pocket (GT-S5300)
Ryan
360 İtibar
1 Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 11
Son 30 Gün: 26
Her zaman: 10,876
