Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy S Blaze cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung Galaxy S Blaze Teardown, The Samsung Galaxy S Blaze: adım 1, 2 resimden 1. Samsung Galaxy S Blaze Teardown, The Samsung Galaxy S Blaze: adım 1, 2 resimden 2.
    • The Samsung Galaxy S Blaze is a 121.9 x 63 x 11.2 mm (4.80 x 2.48 x 0.44 in) phone.
    • Weights 127.6 g (4.48 oz).
    • The resolution is 480 x 800 pixels (~235 ppi pixel density).
    • Released on March of 2012.
  2. Samsung Galaxy S Blaze Teardown, Battery: adım 2, 2 resimden 1. Samsung Galaxy S Blaze Teardown, Battery: adım 2, 2 resimden 2.
    • Take the back plate off.
    • Remove the battery.
  3. Samsung Galaxy S Blaze Teardown, Back Panel: adım 3, 2 resimden 1. Samsung Galaxy S Blaze Teardown, Back Panel: adım 3, 2 resimden 2.
    • Use the Phillips size 00.
    • Remove the 8 4mm visible screws.
    • Then proceed to uncliping the back panel, starting from the top with the blue plastic opening tool.
  4. Samsung Galaxy S Blaze Teardown: adım 4, 1 resimden 1.
    • Once you have taken the back panel you should be able to see the back of the motherboard.
    • The vibrator.
    • The 5 MP camera.
  5. Samsung Galaxy S Blaze Teardown, Motherboard: adım 5, 2 resimden 1. Samsung Galaxy S Blaze Teardown, Motherboard: adım 5, 2 resimden 2.
    • Unclip all 4 ribbons.
    • 3 of the ribbons are located on one side.
    • The 4th ribbon can be found when you flip the motherboard.
  6. Samsung Galaxy S Blaze Teardown, All the parts: adım 6, 1 resimden 1.
    • These are all the parts that will come from the phone if you decide to tear it down.
Jhordan
151 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
where is the combo part ihave to purchase that is body of samsung gt1900
Satish Khadke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 1,173
