Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy S II cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung Galaxy S II Teardown, Samsung Galaxy S II Teardown: adım 1, 1 resimden 1.
    • Step 1- Use an opening tool, or your fingernail into the opening at the top near the headphone jack.
    • Use the tool or your fingernail to pry the opening open.
  2. Samsung Galaxy S II Teardown: adım 2, 2 resimden 1. Samsung Galaxy S II Teardown: adım 2, 2 resimden 2.
    • If an microSD card is inserted, use the flat end of a spudger and push it until you hear a click sound and it will release right after.
    • Once you reassemble the midframe, place the microSD card back into it's slot
    • Do the exact same thing with your battery and do not damage the battery in any way.
  3. Samsung Galaxy S II Teardown: adım 3, 3 resimden 1. Samsung Galaxy S II Teardown: adım 3, 3 resimden 2. Samsung Galaxy S II Teardown: adım 3, 3 resimden 3.
    • Remove all six pf the 4.0 mm Philips #00 screws securing the back of the device to the front
  4. Samsung Galaxy S II Teardown: adım 4, 1 resimden 1.
    • Pry the midframe all around the device to carefully remove it
    • If you do not pry throughout the whole device, the midframe will be very hard to remove
    • A plastic tool opener would be better and it will not damage the phone.
  5. Samsung Galaxy S II Teardown: adım 5, 2 resimden 1. Samsung Galaxy S II Teardown: adım 5, 2 resimden 2.
    • Remove the midframe carefully
    • If your previous midframe was broken, place a new one. When you hear a click sound throughout the device, you know you have snapped it into place
Vanessa Cardenas
241 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,206
