Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung Galaxy S II cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung Galaxy S II Teardown, Remove back of phone: adım 1, 3 resimden 1. Samsung Galaxy S II Teardown, Remove back of phone: adım 1, 3 resimden 2. Samsung Galaxy S II Teardown, Remove back of phone: adım 1, 3 resimden 3.
    • Find the small divot and use a plastic tool or your fingernail to remove the plastic cover off the back. This step requires no removal of screws.
  2. Samsung Galaxy S II Teardown: adım 2, 2 resimden 1. Samsung Galaxy S II Teardown: adım 2, 2 resimden 2.
    • Remove the 11 screws from the back of the phone. This will require a Philips #00 screwdriver.
  3. Samsung Galaxy S II Teardown: adım 3, 2 resimden 1. Samsung Galaxy S II Teardown: adım 3, 2 resimden 2.
    • Separate the screen and internals from the casing on the back by using a small plastic tool or your fingernail to get under the screen and lift it up. Once it has been unclipped, pull the 2 completely apart.
  4. Samsung Galaxy S II Teardown: adım 4, 1 resimden 1.
    • The back of the screen should look like this. From here, we have access to any fixes that would nee to be made for the phone.
Devon Crump
284 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Is this device Galaxy S2 or Galaxy Note2? It seem to be Note2…
jehongjeon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 804
