Giriş
We're completing this week's teardown trifecta with the Gear Fit, Samsung's latest offering that attempts to either sportify a smartwatch, or smartify a sportwatch. Will it leave us as breathless as its brother, the Gear 2, or will it just give us fits? The teardown team is in high gear, so join us and find out!
If high-tech hardware sets your heart racing, you're fit to befriend us on Facebook, trade tweets with us in the Twitterverse, and swoon over some sweet photos on our Instagram.
Neye ihtiyacın var
Videoya Genel Bakış
What did Samsung fit inside the Gear Fit?
1.84” Curved Super AMOLED touchscreen display (432 x 128 pixels)
180 MHz ARM Cortex M4 CPU
Accelerometer, gyroscope, and heart rate sensor
Battery good for 3-4 days of normal use
Bluetooth 4.0 LE
It's a tidy little package, but you know how this works: it's all gotta come out.
"Hey, does this watch have an easily removable band like the Gear 2?"
"Maybe, give it a shot."
"...Yes."
Feel free to ponder that while we go find our fleeing Fit. This here's a teardown, and it's not getting away so easy.
Wrist strap dispatched, it's time for a close-up inspection of the
dark sidewrist-side of the Fit. -
Riding along against your arm, you'll find the heart rate monitor and charging cradle contacts.
They did include a model number: SM-R350, if our eyes do not deceive us.
A single button serves as a sleep/wake and power switch, and is the only significant opening in the unibody enclosure.
And help we shall receive—after we tell you about our exciting product, the iOpener. The iOpener makes repairs safer for you and your devices by gently heating and softening stubborn adhesives, without the danger of melting plastic or warping LCDs that you risk when using a heat gun.
Let's go ahead and throw an iOpener on our device, and—oh, what's that? We already did?
Why hello there, little Fit. Looking pretty cozy there. Sure would be a shame if somebody...
PRIED OFF YOUR FACE.
Thanks, iOpener.
Adhesive softened, a little gentle prying and slicing is all it takes to separate the curved display from the body, hinging on its data and digitizer cables.
This thing is layered like an onion. Let's hope this is a safe place for some prying...
It is! With a wee pop, the cute sushi-shaped innards are free. We personally think it looks like some tasty nigiri (we are a California company after all).
With some careful coaxing, we pick our sushi apart and peel the display assembly off the frame.
We liked the Gear 2's combined digitizer and LCD data cable, but it really isn't that much more effort to disconnect two things to remove the display.
At least these guys never got in the way of our industrious opening tools, unlike others we could name.
At 432 x 128 pixels, the Fit sports just over half the pixel count of the Gear 2's 320 x 320 display.
A close look at the motherboard shows a segmented, three-piece construction, with ribbon cables joining the parts—certainly an interesting approach, in contrast to the rumored flexible PCB of the upcoming wearable iDevice.
Our first stop: disconnect the battery. Next step: figure how to get it out. That's gonna take some digging...
Peeling the Bluetooth antenna up from the side allows us to pop the first segment free of the plastic frame.
This is starting to feel a lot like KP. More peeling as the ribbon cable and contact for the Fit's sole button are spudgered away.
Aww, you're a cute little itty bitty motherboard, aren't you? Yes you are!
It could be a mirage, but is that a battery under there? We'll have to wait to see.
Populating the board, we find this fittingly Lilliputian array of chips:
STMicroelectronics STM32F439ZI 180 MHz, 32 bit ARM Cortex CPU
Macronix MX69V28F64 128 Mb flash memory
InvenSense MPU-6500 6-axis gyroscope / accelerometer
Broadcom BCM4334WKUBG dual-band 802.11n, Bluetooth 4.0+HS, FM receiver combo chip
Maxim Integrated MAX77836 (the same chip we found in the Gear 2—likely the micro-USB interface controller and Li+ battery charger)
Melfas 8FM006A (likely touchscreen controller)
Texas Instruments 1211A1 standalone USB transceiver chip
A small metal strut separates the motherboard from the battery, and protects the unit from over-enthusiastic squeezing, to ensure your Fit is fit for active duty.
The curvy Fit features a curved battery, snugly fitted as a bug in a plastic rug.
Although it is pretty deeply buried, the battery is still equipped with a friendly and useful pull tab. We'll call this "fairly" user-replaceable.
While we couldn't find any useful markings to confirm, Gizmodo tells us this is a 210 mAh battery, with 3-4 days between charges.
That puts the Gear Fit ahead of the Gear 2 in the battery department, due mostly to a simpler OS and its low-power processor.
Samsung Gear Fit Repairability Score: 6 out of 10 (10 is easiest to repair).
While it's a bit of work, users can replace their own battery, greatly extending the useful life of the Fit.
Watch band can be removed and replaced in seconds.
The display is the first component out, easing repair of the most-likely-broken component, but still requires melting adhesive and prying.
Low modularity—peripheral components (home switch, antenna, and vibrator motor) are soldered onto the main board and not individually replaceable without soldering.
The unibody design means any repairs require trucking through the display removal procedure first, risking damage to the LCD.
5 Yorum
Anyone know the pin out for the charging it 5v and gnd thanks
Hello. I need the samsung gear fit sm-r350 service manual and electrical diagram.
Someone has?
