Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Samsung Jitterbug cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: adım 1, 3 resimden 1. Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: adım 1, 3 resimden 2. Samsung Jitterbug Teardown, Samsung Jitterbug Teardown: adım 1, 3 resimden 3.
    • First remove the battery and rubber feet from base and under phone number inside.
    • Undo all six screws. Only the two under the battery will come out fully.
  2. Samsung Jitterbug Teardown: adım 2, 2 resimden 1. Samsung Jitterbug Teardown: adım 2, 2 resimden 2.
    • Pop the six clips indicated in green and remove back. I removed the two on the sides first, but it was a huge pain to open the rest of the way. I suggest starting from the top four.
    • Blue is the connector to the screen and speaker board in the top of the phone.
    • Purple is the chip and orange is charging port.
    • The opposite side of the board (not pictured) has the microphone on it, it's a small black round bump on the bottom.
  3. Samsung Jitterbug Teardown: adım 3, 3 resimden 1. Samsung Jitterbug Teardown: adım 3, 3 resimden 2. Samsung Jitterbug Teardown: adım 3, 3 resimden 3.
    • Unhook screen connector and pop out board (just put a screwdriver under and pop).
    • Peel off button pad.
  4. Samsung Jitterbug Teardown: adım 4, 3 resimden 1. Samsung Jitterbug Teardown: adım 4, 3 resimden 2. Samsung Jitterbug Teardown: adım 4, 3 resimden 3.
    • Remove rubber front, then turn over.
    • Pop all five clips. Start at the top near the hinge and work down.
  5. Samsung Jitterbug Teardown: adım 5, 3 resimden 1. Samsung Jitterbug Teardown: adım 5, 3 resimden 2. Samsung Jitterbug Teardown: adım 5, 3 resimden 3.
    • Blue is main screen and mini screen board. Green is button and underneath is the main speaker. Purple is
    • Pop out all pieces. Be careful not to break the cabling connecting the outer bits to the board.
Kari Fox
125 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 2,112
