Bu teardown bir tamir kılavuzu değildir. Samsung SGH-X450 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Take out the battery and SIM Card.
    • Take out the battery and SIM Card.
  2. Remove these screws.
    • Remove these screws.
    • If the screws are removed, you can take the case of with your fingers or a small flathead screwdriver
    • Now you see the PCB
    • Agere TR09WQTEF2B Processor
    • Agere PSC2106 Power Management IC
    • Battery contacts and power supply connector
    • SIM Card Slot
    • Back-Up battery
    • Antenna connector
    • 2,5mm Headphone Jack
    • LCD Dispaly cable, you can release this connector with a small flathead screwdriver
    • Be careful here, You can break the flatcable!
    • To take the LCD display out of the case, click the upper case open with a small flathead screwdriver or case opener. Under the two pads under the LCD Display are 2 screws.
    • Be also careful here, go not to far with the screwdriver so you can not damage the LCD display.
    • Now you see this.
    • If you want to remove the LCD display, lift the PCB of the LCD display up with a small flathead screwdriver.
    • Finished!
Bryan
690 İtibar
5 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 8
Her zaman: 1,390
