Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Scotch TL901 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Scotch TL901 Teardown, The Laminator: adım 1, 1 resimden 1.
    • The Scotch TL901 Laminator
  2. Scotch TL901 Teardown, Unscrewing the Case: adım 2, 1 resimden 1.
    • Using a small Phillips screwdriver, remove the screws from the bottom of the plastic case.
    • Rubber feet in the four corners must be removed first to gain access to the screws underneath. A sticker may also be covering the middle screw on the left.
  3. Scotch TL901 Teardown, The Opened Laminator: adım 3, 1 resimden 1.
    • Pull off the silver plastic cover and gain access to the internal components.
    • The rollers, motor, circuit board, and LEDs are all visible now.
  4. Scotch TL901 Teardown, The Circuit Board: adım 4, 1 resimden 1.
    • First unplug all three wire headers connected to the circuit board.
    • Unscrew the two screws holding down the circuit board by its corners and remove the board from the laminator.
  5. Scotch TL901 Teardown, The Spring: adım 5, 1 resimden 1.
    • Unhook the spring from the plastic surrounding the motor.
  6. Scotch TL901 Teardown, The Rollers: adım 6, 1 resimden 1.
    • Hold the roller enclosure from both sides, indicated by the markers, and pull upwards and slightly out.
    • Free access to the motor and rollers is now possible.
  7. Scotch TL901 Teardown, The Motor: adım 7, 1 resimden 1.
    • Remove the motor from the rollers by unscrewing the three screws holding them together.
  8. Scotch TL901 Teardown, The Sensor: adım 8, 1 resimden 1.
    • Remove the sensor from the roller enclosure by unscrewing the two spring-loaded screws.
  9. Scotch TL901 Teardown, The Other Side: adım 9, 1 resimden 1.
    • Unscrew the two screws and the bar on the other.
  10. Scotch TL901 Teardown, The Gears: adım 10, 1 resimden 1.
    • Pull the black washers sideways off the metal rod of the roller.
    • Pull the gears off.
  11. Scotch TL901 Teardown, The Disassembled Rollers: adım 11, 2 resimden 1. Scotch TL901 Teardown, The Disassembled Rollers: adım 11, 2 resimden 2.
    • With the gears off, the plastic panel falls off and the rollers come out of the enclosure.
    • The laminator is now disassembled.
Calvin Xu
202 İtibar
1 Kılavuz yazıldı
Ekip
F14BraunReverseEng F14BraunReverseEng üyesi
Community
2 Üyeler
8 adet Kılavuz yazıldı
16 Yorum
Why is the screw on the left side so hard to get out?
Teri L Geist - Yanıt
Thank you..
Putting it back together is more of a challenge.
Frank - Yanıt
You're right Frank. For me, getting it to stay together after the tear down and reassembly required superglue and two extra screws. ;) But at least it's working again. Thanks for the great instructions.
pjcall975 - Yanıt
Thank you! Just needed to open and remove a jam. Followed your guide and all is well.
KQuinn
Kate Quinn - Yanıt
Thank you for posting these instructions. I was able to remove a quarter that got trapped inside.
seanretzloff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 40
Son 30 gün: 138
Her zaman: 29,648
