Ana içeriğe geç
Sharper Image Razor Scooter (Wheel-e Series) Teardown
Neye ihtiyacın var
  1. Sharper Image Razor Scooter (Wheel-e Series) Teardown, Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 1, 1 resimden 1.
    • In order to conduct this teardown you will need (depicted from left to right):
    • 1 Hammer
    • 1 Pair of Channel Lock Pliers
    • 1 Flathead Screwdriver (for prying)
    • 1 Pair of Needlenose Pliers
    • 1 Metric Allen Key Set
    • 1 Pair of Snapring Pliers
  2. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 2, 1 resimden 1.
    • Start by pressing the lock lever with your thumb and unfold the scooter into riding position.
  3. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 3, 3 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 3, 3 resimden 2. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 3, 3 resimden 3.
    • Take the top of the scooter and open the handlebar lock to expose the small screw underneath. (Picture 1)
    • Using a 3mm allen key unscrew the single retaining screw. (Picture 2)
    • Once the screw is removed the clip tightening screw can be removed by hand freeing the whole retaining clip. (Picture 3)
  4. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 4, 2 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 4, 2 resimden 2.
    • Now that the retaining clip has been freed, slide it off towards the handlebars. (Picture 1)
    • Once the retaining clip is removed the handlegrip "T" will now easily slide out of the scooter base. (Picture 2)
  5. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 5, 2 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 5, 2 resimden 2.
    • Moving down the remaining scooter shaft, use a 5mm allen key to remove the lower retaining ring. (Picture 1)
    • Now remove the remaining scooter shaft by unscrewing it from the the wheel and axle. (Picture 2)
    • Hint: Hold the front wheel while unscrewing the shaft to prevent the axle from spinning.
  6. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 6, 2 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 6, 2 resimden 2.
    • Using your hand unscrew the first nut on the axle. (Picture 1)
    • Note: This is the jam-nut used to stop the axle from falling apart.
    • Now using the Channel Lock Pliers remove the axle retaining nut. (Picture 2)
    • Hint: You may have to hold the front wheel to prevent the whole assembly from rotating.
  7. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 7, 3 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 7, 3 resimden 2. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 7, 3 resimden 3.
    • The axle is now able to be slid out. (Picture 1 & 2)
    • Note: this piece could be covered in grease.
    • Now carefully remove the bearing sitting inside of the axle housing. (Picture 3)
  8. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 8, 2 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 8, 2 resimden 2.
    • There will also be a bearing on the axle itself which can also be easily slid off. (Picture 1)
    • Now that the axle is free the front wheel can easily be removed using two 5mm allen keys. (Picture 2)
    • Hint: If you only have one 5mm allen key, the 5mm allen key and the pair of needle nose pliers can be used instead of two allen keys.
  9. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 9, 2 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 9, 2 resimden 2.
    • The rear wheel assembly can now be removed using a 5mm allen key. Use the same process as that to remove the front wheel in Step 8. (Picture 1)
    • The one screw will disconnect the rear wheel and the wheel-e bar from the scooter frame. (Picture 2)
  10. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 10, 2 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 10, 2 resimden 2.
    • The brake mechanism is attached to the base by a steel pin. This pin is difficult to remove, but would be possible with a large press. (Picture 1)
    • Caution: It is our recommendation that you do not attempt to remove this pin unless absolutely necessary. It will be very difficult to get back in place.
    • A torsion spring controls the actuation of the brake. (Picture 2)
  11. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 11, 3 resimden 1. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 11, 3 resimden 2. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 11, 3 resimden 3.
    • Remove all six snap rings from the pivoting assembly. The process for using snap ring pliers is shown in Pictures 1-3.
    • Hint: Three snap rings are shown in Picture 1. The remaining three are on the other side in the same location.
    • Note: It is recomended to wear eye protection during this step since snap rings have a tendency to spring all over the place.
  12. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 12, 1 resimden 1.
    • Remove the black plastic piece indicated in the picture.
    • Hint: Use the screwdriver to get under one of the flanges. It should come off very easily.
  13. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 13, 1 resimden 1.
    • Pry the black plastic piece from the front of the scooter. This will take some work, but the piece will come off intact.
    • Note: This will allow you to see the inner workings of the pivoting mechanism.
  14. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 14, 1 resimden 1.
    • Remove the spring from the inner workings of the pivoting mechanism with the needle nose piers.
    • To remove the spring: First, pull on the visible hook, then push the hook back into the mechanism to remove the tension on the second hook.
    • Leave the spring in the mechanism for now. It will be retrieved once the pins are removed.
  15. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 15, 1 resimden 1.
    • Remove all three pins from the pivoting assembly.
    • Hint: We found it helpful to use the long bolt from the back wheel to hammer out these pins which were difficult to get out. (Picture 1)
    • Note: Once complete, the remaining pieces should fall out as the pivoting piece is removed from the base.
  16. Sharper Image Razor Scooter (Wheel-e Series) Teardown: adım 16, 1 resimden 1.
    • The teardown is now complete.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mark
221 İtibar
1 Kılavuz yazıldı
2 Yorum
aloha ue why not be following the guide introduction in the information is razor scooter not unable to work our ineeding be a chagering please I what to know to me I getting fasteration is my elecrtrical toys bluerazor please has a battery bottom.
michael sears - Yanıt
Mark - would you be able to draw a simple diagram that shows how the springs and levers are oriented to enable the folding mechanism to work properly? I stupidly did not take a close look before tearing down my scooter.
Alex Gurzau - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 14,670
