Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Shift 5.1 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Shift5.1 Teardown, Shift5.1 Teardown: adım 1, 3 resimden 1. Shift5.1 Teardown, Shift5.1 Teardown: adım 1, 3 resimden 2. Shift5.1 Teardown, Shift5.1 Teardown: adım 1, 3 resimden 3.
    • The shift5.1 is the second biggest smartphone in the Shift series and features these specs:
    • 5-inch HD IPS display with a resolution of 1280x720 pixels (293,72 ppi)
    • Mediatek MT6582 Quadcore SoC with 1.3 GHz
    • 2GB DDR RAM + 16 GB internal memory
    • Dual sim (regular and micro sized)
    • 2000 mAh user-removable Li-Polymer battery
    • 5 MP front and 8 MP rear camera
    • Android​ 5.1 Lollipop
  2. Shift5.1 Teardown: adım 2, 2 resimden 1. Shift5.1 Teardown: adım 2, 2 resimden 2.
    • The shift5.1 measures in at 144 x 72 x 7 mm and weighs 140 grams.
    • This makes it about the same size as the Fairphone 2. But a lot thinner.
    • For those who did not already know—it holds a small warning on its rear case:
    • smartphones can be timekillers. there is no greater gift for you today, than the next 24hours. use them wisely. people are more important than machines.
  3. Shift5.1 Teardown: adım 3, 2 resimden 1. Shift5.1 Teardown: adım 3, 2 resimden 2.
    • Having a user-removable battery usually equates to an easily removed back cover.
    • And that's what it is: very easy. We start with a small notch at the lower end of the cover and the flexible black plastic gives way to reveal the battery.
  4. Shift5.1 Teardown: adım 4, 2 resimden 1. Shift5.1 Teardown: adım 4, 2 resimden 2.
    • Taking the battery out is also easy as pie.
    • The 2000 mAh brings you 7.6 Wh at 3.8V, settling behind the 9.2 Wh from the Fairphone 2 battery.
  5. Shift5.1 Teardown: adım 5, 3 resimden 1. Shift5.1 Teardown: adım 5, 3 resimden 2. Shift5.1 Teardown: adım 5, 3 resimden 3.
    • We bring out the Phillips #000 to loosen the seven screws and get further into the shift5.1.
    • A plastic opening tool helps us prying away the plastic frame.
  6. Shift5.1 Teardown: adım 6, 2 resimden 1. Shift5.1 Teardown: adım 6, 2 resimden 2.
    • Before we take the frame aside we take a short look at the loudspeaker which is embedded with a mild double sided adhesive tape.
  7. Shift5.1 Teardown: adım 7, 3 resimden 1. Shift5.1 Teardown: adım 7, 3 resimden 2. Shift5.1 Teardown: adım 7, 3 resimden 3.
    • On the back of the display unit we see the motherboard with a multitude of components mounted on it.
    • We unplug both of the display connectors and peel the volume buttons and power button unit loose from the frame.
    • A single Phillips screw holds the motherboard in place.
  8. Shift5.1 Teardown: adım 8, 3 resimden 1. Shift5.1 Teardown: adım 8, 3 resimden 2. Shift5.1 Teardown: adım 8, 3 resimden 3.
    • Now we can careful lift up the motherboard and take away the 8 MP rear camera.
  9. Shift5.1 Teardown: adım 9, 3 resimden 1. Shift5.1 Teardown: adım 9, 3 resimden 2. Shift5.1 Teardown: adım 9, 3 resimden 3.
    • In regular teardown fashion, we get to work peeling up the strongly-adhered plastic cover in the base of the battery housing.
    • This huge black adhesive plastic foil hides the interconnect cable running from the motherboard to the daughterboard.
    • Breaking up adhesive is usually a destructive process, and this means that a simple daughterboard may become complicated quickly.
    • There is also a little adhesive tape over the daughterboard.
  10. Shift5.1 Teardown: adım 10, 3 resimden 1. Shift5.1 Teardown: adım 10, 3 resimden 2. Shift5.1 Teardown: adım 10, 3 resimden 3.
    • After lifting the vibrator and the microphone carefully out of their recesses we free the daughterboard by loosening two more Phillips screws.
  11. Shift5.1 Teardown: adım 11, 1 resimden 1.
    • And here we have the heart of the shift5.1:
    • Mediatek MT6582 SoC with an ARM Cortex A7
    • Samsung KMR820001M-B609 2GB LPDDR2 memory
    • Mediatek MT6627 Diplexer QVL for WIFI/BT/GPS
    • Mediatek MT6166V RF transceiver
    • Mediatek MT6323GA PMIC
    • AIROHA AP6684 quad-band GPRS front-end module
  12. Shift5.1 Teardown: adım 12, 1 resimden 1.
    • On the flip side we're met with an unfortunate surprise:
    • All the remaining components are soldered to the motherboard, including the front facing camera, headphone jack and the power and volume buttons.
    • While taking a soldering iron to these connections isn't impossible, unskilled users would have trouble replacing these components without damaging their hardware.
  13. Shift5.1 Teardown: adım 13, 3 resimden 1. Shift5.1 Teardown: adım 13, 3 resimden 2. Shift5.1 Teardown: adım 13, 3 resimden 3.
    • Last but not least we have the remaining display which carries the earpiece speaker.
    • Taking it out leaves us with the fused display which carries a GOODiX GT9147 touch screen controller on the flex cable.
    Is that a Goodix touch screen controler on the flex tail?
    Jim Morrison - Yanıt
    Hey Jim, yes it is. Thanks for the hint. We updated the step.
    Tobias Isakeit -
    the display can be changed in 2 ways:
    either with the a-frame or without. if changing only display without a-frame, you only need to open 2 connectors and take of the display and stick the new one on with the sticker-set, that comes with the display. this way you do not need to take out the electronics and you will be done much faster ;-). You can get any SHIFT spare part you want and need at: support@shiftphones.com
    cwaldeck - Yanıt
  14. Shift5.1 Teardown: adım 14, 1 resimden 1.
    • And here we have the shift5.1 spread out on the teardown table showing us all it has to offer.
    wow! we are impressed. thanks iFixit!!! you did a very good job on the content, translation and the pictures!
    cwaldeck - Yanıt
  15. Son Düşünceler
    • Cover and battery are easy to remove and can be swapped without using tools.
    • No excessive glue and no proprietary screws are used, only Phillips #000.
    • Shift offers a forum and a youtube channel with some information and tutorials (unfortunately only in German).
    • The fused display can be changed but you need to take out everything else reminding us of the iPhone 4 and 4s.
    • Lots of components and connectors are soldered to the motherboard. They could be soldered by hand if needed but this makes repairs more difficult.
    Onarılabilirlik Puanı
    6
    Onarılabilirlik 10 üzerinden 6
    (10 en kolay onarılabileni)
Tobias Isakeit
117.588 İtibar
188 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
6 Yorum
cwaldeck - Yanıt
by the way:
cwaldeck - Yanıt
I do not unterstand why it have only a 6 I woud take it between 8 and 9
Sven Ulrich - Yanıt
Only a handful of components aren’t soldered and you have to take a lot apart to change common parts like the display. I understand why it’s not a 8 or 9 but a fully agree I don’t understand why it’s a 6 and not e.g. a 5 or 7. Is there any comparison what has to exist to justify a specific grade?
LastDawn -
jup. we also think a 7 would have been fair.
i think the problem was that the iFixit team took the complicated repair-way. if they followed the instructions from SHIFT for sure it would have been a 7 score. but anyway… this is now long time ago :-)…
cwaldeck -
well, please keep in mind that this phone is from early 2015. we think it should have been a 7, but of cause it is less easy to repair than the m-series, which was the first fully modular phone from SHIFT in 2016 (SHIFT6m or 5me for example). looking back it is maybe amazing to see that this phone is still being supported and spare parts are still availlable (after 7+ years!). also keep in mind that this phone was introduced long time before even fairphone2 existed.
cwaldeck - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 6,399
