Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sidekick II cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sidekick II Teardown, Outer Casing: adım 1, 1 resimden 1.
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Teardown: adım 2, 2 resimden 1. Sidekick II Teardown: adım 2, 2 resimden 2.
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Teardown: adım 3, 1 resimden 1.
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
    Those aren’t Phillips head screws.
    Nae Nae’s Retro Arcade - Yanıt
  4. Sidekick II Teardown: adım 4, 1 resimden 1.
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Teardown: adım 5, 1 resimden 1.
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Teardown, Sidekick II Teardown: adım 6, 2 resimden 1. Sidekick II Teardown, Sidekick II Teardown: adım 6, 2 resimden 2.
    • Remove screen from casing.
  7. Sidekick II Teardown: adım 7, 2 resimden 1. Sidekick II Teardown: adım 7, 2 resimden 2.
    • Remove 4 screws from back of screen using Torx 6 Screwdriver.
    • Pry screen out of casing using fingers.
  8. Sidekick II Teardown: adım 8, 3 resimden 1. Sidekick II Teardown: adım 8, 3 resimden 2. Sidekick II Teardown: adım 8, 3 resimden 3.
    • Remove 4 screws from front of screen with Phillip screwdrivers.
    • Peel off the metal covering on the back of the screen.
    • Be careful when taking off the metal covering. The orange ribbon will not come out all the way, and it is fragile.
  9. Sidekick II Teardown: adım 9, 1 resimden 1.
    • Remove the protective cover in front of the screen.
    • Do not use metal tools, you may damage the protective cover or the screen. Use your fingers only.
  10. Sidekick II Teardown: adım 10, 2 resimden 1. Sidekick II Teardown: adım 10, 2 resimden 2.
    • Take the screws out using the Torx 6 screwdriver.
    • Then lift the thumb wheel and housing off of the front panel.
  11. Sidekick II Teardown: adım 11, 2 resimden 1. Sidekick II Teardown: adım 11, 2 resimden 2.
    • Remove 2 black "rivets" from back of casing with the plastic opening tool.
    • Press keyboard out of front of casing using thumbs. Don't press too hard as you may break the board.
  12. Sidekick II Teardown: adım 12, 2 resimden 1. Sidekick II Teardown: adım 12, 2 resimden 2.
    • Remove the 5 black screws with a Phillips head screwdriver.
    • Lift the bottom of the control board from housing, and separate the two.
  13. Sidekick II Teardown: adım 13, 1 resimden 1.
    • Carefully remove battery and back plate.
    • Do not use metal tools, you may damage the control board. Use only your fingers.
  14. Sidekick II Teardown: adım 14, 1 resimden 1.
    • Here are all of the pieces that you have disassembled
michael albaum
87 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-19, Maness Winter 2010 Cal Poly, Team 3-19, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G19
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
nice job from a former geek
Jared Boies - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 7,249
