Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sky TV Remote cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sky TV Remote Teardown, Sky TV Remote Teardown: adım 1, 3 resimden 1. Sky TV Remote Teardown, Sky TV Remote Teardown: adım 1, 3 resimden 2. Sky TV Remote Teardown, Sky TV Remote Teardown: adım 1, 3 resimden 3.
    • This is it. Well, this is it in a functional state.
    • Remove the batteries before starting!
  2. Sky TV Remote Teardown: adım 2, 3 resimden 1. Sky TV Remote Teardown: adım 2, 3 resimden 2. Sky TV Remote Teardown: adım 2, 3 resimden 3.
    • Use a Philips head screwdriver to remove this screw
    • Use a spudger to unlock all the tabs around the sides, start at the bottom
    • Work your way all the way around the remote, this is flippin' tricky.
    • Brute force is compulsory.
  3. Sky TV Remote Teardown: adım 3, 3 resimden 1. Sky TV Remote Teardown: adım 3, 3 resimden 2. Sky TV Remote Teardown: adım 3, 3 resimden 3.
    • After all the tabs are off, the body should just fall away leaving the buttons, the circuit board, the case and the black infra-red bit at the end.
    • Ta-daa!
3 Yorum
On early models theres a second screw under the black infa red filter. If it doesnt come apart as above, ther black filter is held on by two tabs. On the battery compartment side, the black plastic nearest the battery, wedge a small screwdriver between the body and the pastic and the filter should slide away revealing a second screw!
tim - Yanıt
How do I clean? Buttons not making electrical connection. New remots don't recognize my TV.
Ronald Welemin - Yanıt
Also, is there a product that I can put on the connection buttons to improve contact?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 196
Her zaman: 17,015
