Giriş
I had ants nesting in my Play 5. My choices were burn it with fire, or tear it apart.
Neye ihtiyacın var
Pull the front bezel forward to remove. It's only secured by velcro
Of the 8 screws securing the speakers to the casing, two are hidden behind thick rubber bungs, which need to be removed.
There are also a number of smaller philips screws underneath felt-like padding on the base of the unit. These also need to be removed.
Much of the circuitry is covered in some sort of epoxy resin, making maintenance virtually impossible
