Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sonos Play 5 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sonos Play 5 Teardown, Sonos Play 5 Teardown: adım 1, 1 resimden 1.
    • Pull the front bezel forward to remove. It's only secured by velcro
  2. Sonos Play 5 Teardown: adım 2, 3 resimden 1. Sonos Play 5 Teardown: adım 2, 3 resimden 2. Sonos Play 5 Teardown: adım 2, 3 resimden 3.
    • Gently peel the rubber base away from the edges to remove 6 phillips head screw.
    • The base plate will lift straight up to reveal 3 metal stanchions. I believe these are the wireless antennas.
  3. Sonos Play 5 Teardown, Step 3 - Remove the 12 philips screws to release the Speaker panel from the case: adım 3, 1 resimden 1.
    • Of the 8 screws securing the speakers to the casing, two are hidden behind thick rubber bungs, which need to be removed.
    • There are also a number of smaller philips screws underneath felt-like padding on the base of the unit. These also need to be removed.
    • Much of the circuitry is covered in some sort of epoxy resin, making maintenance virtually impossible
Tim U
101 İtibar
1 Kılavuz yazıldı
Bir Yorum
This teardown is stale! Please continue. :) Thanks.
William Small - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 75
Her zaman: 14,761
