Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Bu Teardown'da Kullanılan Aletler
Giriş
This is my first Teardown! Please don’t be negative about it. But, Constructive Criticism is welcome.
Bu teardown bir tamir kılavuzu değildir. Sony Audio System RM-S100 Remote cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. On the back of the remote there will be a battery cover. Open it up. On the back of the remote there will be a battery cover. Open it up.
    • On the back of the remote there will be a battery cover. Open it up.
  2. See the little tab? Don't break the tab when you open it. That will make it un-close-able! Use your Spudger to open it up
    • See the little tab?
    • Don't break the tab when you open it. That will make it un-close-able!
    • Use your Spudger to open it up
    • Don’t snap your Spudger!
    • This is so incredibly hard to open. I recommend also using a 3.5mm Flat Head so you don’t snap your Spudger.
    • Voila! (Whatever that means...) Its open!
    • This is very hard to open without breaking the tab or your Spudger. The repairability score will take a hit.
  3. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Let’s start by removing the red thing. You can remove it with your fingers. Now pull out the PCB. (It is best to pull by the springs.)
    • Let’s start by removing the red thing.
    • You can remove it with your fingers.
    • Now pull out the PCB. (It is best to pull by the springs.)
  5. Pull out the button pad. Now, pull out the spring.
    • Pull out the button pad.
    • Now, pull out the spring.
    • And thats it!
  6. A total of 7 parts. (I was expecting more.)
    • A total of 7 parts. (I was expecting more.)
    • I would give this a repairability score of 8 out of 10.
    • I almost Broke by Spudger =(
    • Insanely hard to open.
    • Easy to disassemble... once open.
    • No screws. (No Screws to lose! No need remember which screw goes where.)
    • Easy to assemble...unless the tab was broken.
Aiden Baker
13.354 İtibar
20 adet Kılavuz yazıldı
3 Yorum
This is a great first teardown! =) Keep it up!
Sam Goldheart - Yanıt
Thanks! I would do more but I don’t have much junk to disassemble that I don’t need.
Aiden Baker -
Hi @captainsnowball ,
FYI
voilà French exclamation - meaning “There it is!” or “There you are!”
The “red thing” in Step 3 is most probably an IR filter, to filter out visible light to improve IR operation
jayeff - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 1,854
