Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sony D-822K Car Discman cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony D-822K Car Discman Teardown, Sony D-822K Car Discman Teardown: adım 1, 1 resimden 1.
    • Obtain a D822-K Discman and remote. True, it has DSP and Surround Sound, but the 90's have come and gone. It's okay to take it apart.
  2. Sony D-822K Car Discman Teardown: adım 2, 1 resimden 1.
    • Position unit so that the bottom is facing up. Remove the 6 screws.
    • Hold top and bottom of unit together as you turn the unit over, bottom facing down. Use caution; the upper and lower case, along with circuit board are now loose.
    • Watch out for the AVLS and illumination switches, they love to disappear when unsupervised. Remove top of case.
  3. Sony D-822K Car Discman Teardown: adım 3, 3 resimden 1. Sony D-822K Car Discman Teardown: adım 3, 3 resimden 2. Sony D-822K Car Discman Teardown: adım 3, 3 resimden 3.
    • Removing the CD reader: Gently pull all 3 rubber grommets sideways, away from the CD reader.
    • Slide edge of ribbon cable connector towards ribbon cable to disengage.
    • Unplug the red, white, and blue plugs from the circuit board.
  4. Sony D-822K Car Discman Teardown: adım 4, 2 resimden 1. Sony D-822K Car Discman Teardown: adım 4, 2 resimden 2.
    • Observation: This is the Hydro Suspension system...really.
  5. Sony D-822K Car Discman Teardown: adım 5, 3 resimden 1. Sony D-822K Car Discman Teardown: adım 5, 3 resimden 2. Sony D-822K Car Discman Teardown: adım 5, 3 resimden 3.
    • Remove circuit board
    • Notice the dual-color light modules. (I temporarily connected the power to show off the lights)
  6. Sony D-822K Car Discman Teardown: adım 6, 1 resimden 1.
    • Disconnect tailpiece, and power supply.
  7. Sony D-822K Car Discman Teardown: adım 7, 2 resimden 1. Sony D-822K Car Discman Teardown: adım 7, 2 resimden 2.
    • Remote: Remove the 3 screws from the bottom. Pull apart.
    • The function buttons have a neat overlay design.
  8. Sony D-822K Car Discman Teardown: adım 8, 1 resimden 1.
    • Completely disassembled. The illumination button was lost for two weeks after reassembling... but who uses amber lights anymore?
modem21
84 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 18,085
