Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Sony Ericsson K750i cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony Ericsson K750i Teardown, Battery Cover: adım 1, 1 resimden 1.
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Teardown, Back Casing: adım 2, 1 resimden 1.
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Teardown: adım 3, 1 resimden 1.
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Teardown: adım 4, 1 resimden 1.
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i Teardown, Keypad: adım 5, 1 resimden 1.
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i Teardown: adım 6, 1 resimden 1.
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i Teardown: adım 7, 2 resimden 1. Sony Ericsson K750i Teardown: adım 7, 2 resimden 2.
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i Teardown, LCD Screen: adım 8, 1 resimden 1.
    • Remove the screws holding the screen in place.
  9. Sony Ericsson K750i Teardown: adım 9, 1 resimden 1.
    • Gently lift the base of the keypad to remove it.
  10. Sony Ericsson K750i Teardown: adım 10, 1 resimden 1.
    • Gently pull up the green film, avoiding the joystick.
    • The LCD screen will be attached to this film and come off with it.
  11. Sony Ericsson K750i Teardown, Sony Ericsson K750i Teardown: adım 11, 1 resimden 1.
    • Remove the back cover from the phone.
    • Gently slide the ribbon out of its connection.
  12. Sony Ericsson K750i Teardown: adım 12, 2 resimden 1. Sony Ericsson K750i Teardown: adım 12, 2 resimden 2.
    • Lift the motherboard out of the phone.
    • The ribbon is fragile so work the motherboard off around the ribbon to prevent damage.
  13. Sony Ericsson K750i Teardown: adım 13, 2 resimden 1. Sony Ericsson K750i Teardown: adım 13, 2 resimden 2.
    • Pry off the microchip that is located below the ribbon.
  14. Sony Ericsson K750i Teardown: adım 14, 2 resimden 1. Sony Ericsson K750i Teardown: adım 14, 2 resimden 2.
    • Lift out the plastic support to complete the teardown.
Abby Evers
202 İtibar
6 adet Kılavuz yazıldı
Ekip
UW Stout, Team 1-6, Zhou Fall 2011 UW Stout, Team 1-6, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G6
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Very helpful!
Nibhish Naik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 12,449
